Pulsar GTiR - Engine fubar, 08/07/2008
#285
Yup, think so. I only seem to insure it every other year, the rest of the time it sits in the garage gathering dust and scratches whenever I walk past it. I could do with the cash more than the car atm especially as nipper #2 is due in 23 days.
James
James
#288
good luck with the build Rad
here's a link to my mates rebuild thread http://www.gtiroc.com/forums/showthread.php?t=45633
if you need any info etc in a hurry just drop me a text
#289
Unlucky Rad.
You've had no luck with this one. Your plans sound good for this one what are you gonna do with the box and diffs as your putting a fair bit of power through them on the new spec??
#290
Cheers Ben.
Smithy, I have a spare box that will be rebuilt. Standard gearset, steel selector forks and casing modded. Should be fine so long as I don't launch it, Which I don't.
Rear diff should be fine also, with regular oil changes, Not heard of many break if any.
One thing I do want though is a better front diff.
In the long run, Once I've cleared some debt etc, I may go for a Quaife or a PPG gearset.
#291
Bets its the lands that have gone not the rings.......
JE forged pistons standard head 1.2mm HG HKS 3037 1.5 bar Z32AFM 272 CAMS and a power FC pro with the mapable software conversion thingy.
SWEEEEEET
SWEEEEEET
#292
Cheers Ben.
My mates one use to love 6k and drop the clutch lol
#294
The only time I plan on launching it is at the Pod
Edit: I have a few times, But I don't make it something I do often.
Raced a 380bhp pulsar off the lights and done him, then he killed me, Then he done me at the 2nd set of lights. Done a scooby to, and I was 4 up LOL
#298
well radders, I put a conrod though the block on friday night so game over one boxer engine.
o well the mrs is about to sign for a top model agency(eg not clothed pictures lol) so should be able to build a good spec engine lol
#305
Yes the pulsar seens to have more problems/niggles than most of the import cars, hope you have deep pockets , there is plenty to go wrong , handbrake cables , abs sensors , wheel bearings , gearbox/clutches the list is long , good luck
#307
You probably can, anything is possible with money.
I was looking under an Evo 6 the other day at the box/diff etc, I reckon it could go, But it means changing the rear diff + 4 drive shafts, which would be custom.
PPG Pulsar box (straight cut), plus the bracing and bits and bobs to make the casing stronger, Your looking at 5k..
If I could get an Evo box/diffs fitted for that then I would. Cars on hold at the mo anyway, I'm not working
#312
good thread,shame you have such bad luck !
i had 1 a few years ago and fancy another,pref white
lots of car for little money imo
#314
It Wasnt Me!
fuck sake Rad if it wasnt for bad luck you'd have none at all mate!!!!
Good your sticking with it tho, it will be a great car just needs time and money put into it!
and yes, those inlets are a C*NT especially to fit/remove on an S14 !!!
oilman
Trader Parts for Sale.
30-08-2015 08:37 AM
