Danish Escort Rst S2 project. BIG SPEC ZVH - 18/9-2011 Engine and gearbox DONE!! Pics
#44
Nice :-)
Just having them as a backup makes me sleep better at night he he
#46
A little update...
Hi there ...
A little fast update... Dont have time for a big post, But there is always room for some pics ...
Thats all for now ....
#48
The other rims have been replaced by th 7œx 17 rs Seven spoke. My Focus Rs Brakes could'nt fit under the Keskin Wheels. So i went for the "original" wheels
#50
A "small" update ;-)
Just at fast update on my little project...
Its been a year since my last update. But due to a new job and a lot of overtime - not much has happened on the S2 :-(
But SOME progress has been made he he...
Here is a short spec list on the engine so far:
2 litre Zetec silvertop bottom end - Fully balanced with HD bearings and ARP bolts all over
Focus Rs pistons and rods
Cometic ZVH headgasket
EFI head - fully custumized to my needs by myself ... And partly thumbs up from SiTech
Newman 200 ft double valve springs
Newman ZVH camshaft. (not purchased yet - looking for other specs than the standard one)
Kent cams Solid lifters
Brian Hansen Tubular manifold
Garret GT2860Rs
MDS Coil
Magnacor cables
OMEX 600 Ecu
Cosworth 3" Group A filter
Helix 4 paddle clutch
Etc etc etc... Forgotten a lot of the parts
Hoping for a solid 300 bhp and around 400 Nm
The first pictures of the engine is only from a brief testfitting. This weekend i am beginning the engine assembly ...
testfitting
The head
That all for now ...
More pics will follow shortly
Garret GT2860Rs
MDS Coil
Magnacor cables
OMEX 600 Ecu
testfitting
The head
#54
A small update ;-)...
Just a few pics from the engine assembly... Enjoy
Unfornunately one of the used Focus Rs rods was faulty. So i has not come around putting the pistons and rods in yet :-( :-(
So guess I'll have to wait a bit for a new/used rod.... ANYBODY GOT ONE???????????
#57
He he...
Jeg er bange for det hele står lidt stille nu. Køber bare en masse stumper. Men får ikke rigtigt samlet noget :-(...
Men mon ikke det kommer igen
#58
to find a solid rst shell like yours over here its impossible, well for under £2k anyway! most are rotten
Looks awesome now though on the rs7s and will be perfect with that zvh inside
#60
A small update :-)
Well I have to put theese pictures up for you to see .
Just finished painting the head, gearbox and a few other aluminium parts.
After a little research i found out what kind of primer to use for alloy. Due to the heat from the engine i was adwised to use "Wash primer" for this project. (thats the yellow stuff on the pics)...
And suddenly it all turned into mat black
I also pretty much finished on assembly of the block (2 litre Zetec with Focus Rs pistons and Rods)
And with the head on
#67
3,5 years gone by.... Engine and box fitted!!! :-)
Not much to say right now. Enjoy the pics
First of all . Rs Turbo meeting in denmark at its biggest ever he he
And then - Gearbox time . Uprated Ib5 box with a S2 Lsd and big bearings. Fully rebuilt and painted by myself.
Homemade cambelt cover - just needs some welding
Then the car was ready for some brakes, engine and gearbox
Then i got around fitting my 4 paddle Helix Clutch and the engine.
Like a glove
Fully rebuilt driveshafts - new joints, powdercoated etc.
On its wheels again after a good weekend!!
Like a glove
#69
Hvor kommer vi egentlig til at se bilen henne ad i landet?
Det er en fryd for øjet HVER gang at se dine billeder, men en så fin karosse... Og ja okay, motoren kan jo lige gå an :P
Sorry for the danish PF. Just asking where to see the car and it's looking amazing!
#71
Og Tak for de pæne ord ..
#72
He he
Ja nu er jeg jo jævnligt i skive ved en kammerat, så det kan da være du får den at se når den engang kommer ud at køre ...
#76
Er der en anden måde at kontakte dig på... F.eks. MSN, så du bare lige kan fyre en besked afsted, hvis du kommer herop i den. Vil satme gerne se en "spritny" Escort
