F2 Maxi Build Lucifer II - RL7's and a BIG Turbo!
Old 23-06-2013, 09:36 PM
  #1121
mothrs2k
mothrs2k's Avatar
nice work mate!
its certainly taking shape now
Old 25-06-2013, 07:22 PM
  #1122
Minirotty
Lucifer II - 666
Minirotty's Avatar
Thanks bud
Old 26-06-2013, 05:06 PM
  #1123
Minirotty
Lucifer II - 666
Minirotty's Avatar
Billet flywheel arrived today, it's ridiculously light!
Old 27-06-2013, 06:23 PM
  #1124
Minirotty
Lucifer II - 666
Minirotty's Avatar
Forgot to mention it's 3.9 kilo's
Old 27-06-2013, 06:53 PM
  #1125
Mark V8
Mark V8's Avatar
That looks the business
Is it a RS2000 one or do Zetec ones fit ?
Old 27-06-2013, 07:03 PM
  #1126
Minirotty
Lucifer II - 666
Minirotty's Avatar
No mate the RS is 20mm bigger than a Zetec flywheel, well the clutches are 20mm difference.
Old 30-06-2013, 09:14 AM
  #1127
Minirotty
Lucifer II - 666
Minirotty's Avatar
Thanks to Jim (SCS) and the heads up re-trigger wheel wrapping themselves round cranks past 8500 revs, something I have not seen before but now I know it can happen it gave me RS paranoia! Thanks Jim lol
I started looking at other engine I have in stock and looked at a couple of the mountune cranks I have and found a difference on their trigger wheels.
They have billet steel ones fitted.
So... stripped my bottom end down, knew there was a reason I didn't final torque my rods... and fitted the billet steel trigger wheel.
On the standard you can bend teeth by hand, billet one you have no chance without a hammer lol
Also had a problem with adjustable cam sprockets as the bolts in a few had rounded off when I tried to reset them, Ian (Coley) drilled them out for me yesterday and I'll get new bolts asap.
Older pic's not working atm because photobucket want some money, I am not paying so they'll show up again soon.
Old 30-06-2013, 10:12 AM
  #1128
andy escos
andy escos's Avatar
bottom end looks real good
Old 30-06-2013, 10:37 AM
  #1129
Received 1,044 Likes on 998 Posts
You defo dont want a weak trigger wheel.
Old 30-06-2013, 11:03 AM
  #1130
COLEYST200
COLEYST200's Avatar
I got them spacers done for you last night kev
Old 30-06-2013, 07:50 PM
  #1131
Minirotty
Lucifer II - 666
Minirotty's Avatar
Thanks Andy
He gave me para
Nutta, thanks though mate
Spent today at unit with bad head as had hangover lol
But finished off engine bay and fitted ARB, not easy with subframe bolted to car lol
Then I set about building engine and attaching to box, but snapped a clutch plate bolt in flywheel and nearly gave up for the day but me mate Shaun turned up and gave moral support lol used his Scooby to shoot off to other unit and get new bolts...
Then... engine in!
All wrapped up now, I've loads of bits to sort out now, peddle box next after timing sorted on engine as not done that yet due to the sprockets needing drilling out etc.
Modify manifold also as doesn't quite clear the sump, but needs chopping anyway for new system etc...
Feel like I can plod on again now without massive modifications needed although still need lots of money spending
Old 30-06-2013, 08:40 PM
  #1132
COLEYST200
COLEYST200's Avatar
looking good KEV
Old 30-06-2013, 09:29 PM
  #1133
Minirotty
Lucifer II - 666
Minirotty's Avatar
Cheers Ian bud
Old 30-06-2013, 09:38 PM
  #1134
Madgit
Works and plays on track
Madgit's Avatar
How long until she moves under her own steam mate?
Don't give me the "you can't rush it BS" lol.
Old 30-06-2013, 10:06 PM
  #1135
Minirotty
Lucifer II - 666
Minirotty's Avatar
Finish it next week if you fancy giving me 4/5K mate?
Old 30-06-2013, 10:12 PM
  #1136
Madgit
Madgit's Avatar
Leave it with you then, no rush bud
Looks great though
Old 30-06-2013, 10:20 PM
  #1137
Minirotty
Lucifer II - 666
Minirotty's Avatar
cheers Adam bud.
Old 04-07-2013, 04:34 PM
  #1138
Minirotty
Lucifer II - 666
Minirotty's Avatar
Present arrived today from Andy @ ALDevelopments 50% throw quickshift.
He did also send me a few pic's of its construction to show me how indestructible he has attempted to make it as he knows how much abuse I have given his 25% ones in the past pmsl
He's welded this one together
Good timing as I can now bolt it on mext time I am the unit.
Old 04-07-2013, 08:46 PM
  #1139
dobermann1234
WRC S1cos coming soon!!!
dobermann1234's Avatar
Cars going to be a beast mate
Old 04-07-2013, 09:44 PM
  #1140
Minirotty
Lucifer II - 666
Minirotty's Avatar
Thanks bud
Old 05-07-2013, 10:19 AM
  #1141
Cool.Whens the engine get built back up.
Old 05-07-2013, 11:41 AM
  #1142
Minirotty
Lucifer II - 666
Minirotty's Avatar
What do you mean Glenn?
Old 05-07-2013, 01:33 PM
  #1143
I should of said when is the engine getting built back up so it will run cause in the pics it has loads of bits not fitted yet.
Old 05-07-2013, 04:17 PM
  #1144
Minirotty
Lucifer II - 666
Minirotty's Avatar
Arh get ya
Waiting on some bolts for my ajustable cam sprockets as had to drill then out, thats why wasn't timed up before fitting.
Old 05-07-2013, 04:42 PM
  #1145
COLEYST200
COLEYST200's Avatar
I got all the steel and ally I need to make all your uver parts today kev and I'm working in Birmingham this week coming
Old 05-07-2013, 08:44 PM
  #1146
Minirotty
Lucifer II - 666
Minirotty's Avatar
Thanks mate you're a star!
Old 12-08-2013, 10:34 PM
  #1147
Minirotty
Lucifer II - 666
Minirotty's Avatar
went to Ford fair this weekend and went out in my mate Simons Blue Oval Saloon Championship winning RS2K powered escort, gave me a right buzz about mine as mine will be faster lol
Managed to get a rocking horse shit cast aluminium thermostat housing that mountune produced back in the 90's as a lad on RS forum managed to get some old stock from them.
off for rest off week so gona be up unit messing when I can bit plan on messing with wiring next.
Old 14-08-2013, 10:26 AM
  #1148
.Ross.
.Ross.'s Avatar
One of the coolest builds in these boards.
When's this bag 'a' hammers gonna hit road KEV?
Old 18-08-2013, 03:35 PM
  #1149
Minirotty
Lucifer II - 666
Minirotty's Avatar
Thanks mate and duno lol done when it's done mate but it's getting there now.
the thermostat housing looks good in the bay.
Old 18-08-2013, 07:42 PM
  #1150
Minirotty
Lucifer II - 666
Minirotty's Avatar
The white mk6 poverty spec shell I purchased a little while ago was for the wiring...
Today I started looking at it lol
Got to try and figure out what I need and don't need from this lot...
I managed to reduced it to this...
Still loads to remove yet but don't want to chop something out I later need lol
It's a learning curve again as I hate wiring.
Old 18-08-2013, 10:27 PM
  #1151
COLEYST200
COLEYST200's Avatar
Looking good kev we need to finish your parts off ASAP
Old 19-08-2013, 07:18 AM
  #1152
IainRS1700T
IainRS1700T's Avatar
Looks like you've already reduced your loom down nicely - that's half the battle.
My old Sierra one was so cut up & old I've had to start again!
I'm with you on hating the wiring - I've got two days on it this week. Normally I love having time set aside to work on the car but this week I'm not so sure..
Iain
Old 19-08-2013, 11:36 AM
  #1153
Minirotty
Lucifer II - 666
Minirotty's Avatar
Cheers mate, I'll pop over whenever you're ready
Iain
Looks better in the 2nd pic that it actualy is Iain Still loads to do and figure out on it.
I don't want to remove somehting only to find I have messed it up and needed it lol going to try and plod on with it this week of an evening if I can keep my motivation up to do it.
I want to than get some nice wire covering to make all the loom look tidy in the car too, if you've got any recommendaitons?
Old 19-08-2013, 12:04 PM
  #1154
whizzisat114
whizzisat114's Avatar
Polyester loom braiding kev
Old 23-08-2013, 08:45 PM
  #1155
rs_daz
rs_daz's Avatar
Looking very good fella ! Some tasty parts going on !
Old 03-10-2013, 05:04 PM
  #1156
Minirotty
Lucifer II - 666
Minirotty's Avatar
Bit of a head ache lately sorting out all the JIC AN fitting sizes but I think I am on top of it now.
As with a few they weren't strait forward but after Coley measured for me it seems some are 5/8 BSP to -16, started ordering these up for the dry sump system.
Also had head ache with trying to mount my 52's onto my CNC DTH inlet, as you'll see in the pics, inlet machined with 8mm holes for mounting but I couldn't get the 8mm stud or cap head to work on tb's because injector housing is to low.
So thanks to Mick following my design request he made me some 8mm to 6mm thread / stud reducers, they worked well.
Some pics -
The start of JIC fitting killing wallet exercise
The reducers -
the reason 8mm wouldn't work -
The bodies built up now with underslung cable mech as above doesn't fit because of angle and DTYH manifold -
More when I start fitting bulk head up for dry sump, fuel lines and also PAS lines from electric PAS pump.
Old 03-10-2013, 05:11 PM
  #1157
frsjon
frsjon's Avatar
great work kev...6 years in the making
Old 03-10-2013, 05:14 PM
  #1158
Minirotty
Lucifer II - 666
Minirotty's Avatar
Thanks Jon and I know mate But she'll be worth it when finished, no matter when that is
Old 04-10-2013, 03:35 PM
  #1159
Minirotty
Lucifer II - 666
Minirotty's Avatar
First of the -16 parts arrived today, expensive journey ahead
For the dry sump main feed -
Old 04-10-2013, 09:55 PM
  #1160
COLEYST200
COLEYST200's Avatar
Shit me that's big mate
Quick Reply: F2 Maxi Build Lucifer II - RL7's and a BIG Turbo!
