My Escort Cosworth, now on the road again ...
Old 30-10-2007, 10:55 PM
  #81
DENNIS
DENNIS's Avatar
Originally Posted by NEEDFORSPEED
yeah definately cheers! id be happy with 450 but very drivable/responsive/reliableish! have been thinking about throttle bodies too but need to look into it more. think a swedish will be too big for my needs. (have a look at my thread) is your friend a mapper??
i will do then, he is and has loads of experience with the motec systems..
looks like we have a similar plan , i have not decided on injectors just yet although i will most likely be using 750cc , as at that power ( 450-500 )620 cc on a 4 cyl is ideally needed as i never like to run more than 80% injector duty.
i have a swedish plenum on order, but like your thinking of throttle bodies
will look, do you have a link
Old 30-10-2007, 11:12 PM
  #82
NEEDFORSPEED
NEEDFORSPEED's Avatar
https://passionford.com/forum/viewtopic.php?t=240033
we have exactly the same ideas lolhow much of a gain would you expect using tb's do you think? i see reyland uses them but not seen anyone else using them i dont think?
Old 30-10-2007, 11:16 PM
  #83
NEEDFORSPEED
although fly by wire . . . . god knows lol
Old 31-10-2007, 06:28 AM
  #84
Charlie Chalk
Unknown.
Charlie Chalk's Avatar
Nice work Dennis, Can't believe how clean it is!
Throttle bodies are mainly for response,.. Mike R also has now gone down the ITB's route on his Escos
Id stay Big throttle body personally on a normal road car, Plus its easier to map on a single throttle body
Im lucky my GTiR comes with throttle bodies, So im staying.. just for the sake of having them
Old 31-10-2007, 09:42 AM
  #85
Mike Rainbird
Caraholic
Mike Rainbird's Avatar
Dennis,
If you were finding that the revving up on initial start was annoying, you should have just put a post up and I would have told you how to connect it to your switch so that the ALS valve was isolated from the ISCV test procedure (where the ECU sends a signal to pulse the ISCV to clean it, every time the ignition is turned on).
Have fun anyway .
Mine is now on T6 and the Mountune roller barrels and response is very good with a huge spread of power from 3500 to 8500 (still has 500bhp at 8500 rpm) .
Old 31-10-2007, 04:39 PM
  #86
scotty86d
scotty86d's Avatar
impressive stuff, like the fact you are getting more advanced ecu etc to obtain better driveability over max power
Old 31-10-2007, 11:26 PM
  #87
DENNIS
DENNIS's Avatar
Dennis,
Have fun anyway .
mike, i have had it unplugged and it still used to rev up on start up, connecting the signal wire via the switch is something i am aware of, but as it made no difference in this instance it was seen as a waist of time. but as i say it was only one of a list of issues i had..
by the way, you don't have a small turbo escort crank pulley do you ?? (36 - 1 ) i have had one on order from fords for 7 weeks now and its holding me back ??
cheers ...
Old 31-10-2007, 11:39 PM
  #88
DENNIS
DENNIS's Avatar
thanks , driveability and reliability are more important to me than raw numbers..
Old 31-10-2007, 11:45 PM
  #89
NEEDFORSPEED
ive been tols by a few that theyre not available anymore from ford?if you have luck with it please let me know!
Old 01-11-2007, 01:40 PM
  #90
Mike Rainbird
Caraholic
Hi Dennis,
Sorry I don't, but Steve Scott from A1 will have .
There's quite a bit you have to do to the switch as it needs a relay connecting in a certain way, but you have removed it, so no worries .
Old 01-11-2007, 06:37 PM
  #91
DENNIS
DENNIS's Avatar
cheers mike, ordered one from them today...
Old 05-12-2007, 07:57 PM
  #92
DENNIS
DENNIS's Avatar
OK updates... i have been very busy at work so progress has been a bit slow...
never the less i have still made some progress...
my new Wossner pistons..
WRC spec 6 long studs...
my new intake plenum and port matched intake
i have now ported my head and flow tested it ... with a 22% increase in flow...
i have had all my bolts electroplated ....
i will be sending all the rotating bottom end off for balancing before it all goes back together...
i have also made the decision to lose the anti lag
i don`t know if i have made a decision i will regret or not
as some may of noticed the project is now in fast ford ... Thanks guys
Old 05-12-2007, 08:06 PM
  #93
NEEDFORSPEED
brilliant. thanks for putting me on to sam btw just awaiting an e mail back. was very helpfull unlike most and knows his stuff! parts look
Old 05-12-2007, 08:19 PM
  #94
luke89
Team HOTHOT!
luke89's Avatar
awsome, how comes you desided to get rid of the anti lag?
Old 05-12-2007, 08:28 PM
  #95
DENNIS
DENNIS's Avatar
i have been undecided for some time,i do like the ALS, but i intend on closed loop lambda control, and it will cook the sensors on a regular basis.. also this build is costing a few quid and don't want to harm it unnecessarily.. as i was looking for reliability, it seams to do more harm than good..
Old 05-12-2007, 08:29 PM
  #96
DENNIS
DENNIS's Avatar
no problem .. will chase him in the morning for you ..
Old 05-12-2007, 08:54 PM
  #97
CliffRS4
CliffRS4's Avatar
Good to see your progress in here and in Fast Ford mag Dennis
Old 08-12-2007, 07:45 PM
  #98
DENNIS
DENNIS's Avatar
cheers..
a few more bits.. i have removed the old dizzy, and made a replacement oil pump drive ( not yet finished )
and the new cam sensor set up..
Old 08-12-2007, 07:47 PM
  #99
NEEDFORSPEED
factory look. like it. lets see the cam lol!
Old 08-12-2007, 07:52 PM
  #100
DENNIS
DENNIS's Avatar
i will get some pics up soon, was actually a bit harder than i thought, as i had to change some of the materials to get a clean signal,,
i wanted to keep it looking " factory finish " as i personally think the sensor in the top looks ugly....
Old 08-12-2007, 09:06 PM
  #101
NEEDFORSPEED
ditto. i opted for the small turbo escos one tho i dont know how good/efficiant it is. when you hopeing to get it finished by?
Old 10-12-2007, 07:38 PM
  #102
DENNIS
DENNIS's Avatar
i was going to use that as well, but are hard to find...
also if i change the intake cam timing, the sensor will not see this change as its on the oil pump drive rather than on the cam it self..
but it will work just the same...
i am not sure when it will be done as i can only really work on it during " down time " and my free time at work, and we are quite busy at the moment.
but i should have all the bits back from balancing this week, so it should not be long till its back together, then running it in on the dyno..
how about you ??
Old 10-12-2007, 07:45 PM
  #103
NEEDFORSPEED
good stuff. hmm not sure really hopefully april. saveing for a manifold/turbo at the mo. ordered management today too. then buy a haynes to put it all back together haha do you know the dwell of the coils your using? im not sure where to find out i should think mine will be the same as yours being the same make?!
Old 10-12-2007, 07:59 PM
  #104
rapidcossie
rapidcossie's Avatar
would the benifits of antilag not out weigh the lambda control fueling on a car that would do minimal miles?
Old 10-12-2007, 08:08 PM
  #105
DENNIS
DENNIS's Avatar
cool, what manifold are you going for ??
as for the dwell time`s i have not got that far yet, but the time will depend on the manufacturer's parameters for charge time`s ( most likely around 3-5 millisecond's..
are they denso items ??
if so if you give me the denso part number i will get them at the same time ...
Old 10-12-2007, 08:14 PM
  #106
34CHASSIS
34CHASSIS's Avatar
HI WHO MADE THE PLENUM
Old 10-12-2007, 08:15 PM
  #107
DENNIS
DENNIS's Avatar
hmm you do have a point, i have actually decided to keep the valve on the manifold ( now modified ) set up BUT not connected as yet, i may program it back in on the new ecu at a later date... with some shielding on the sensor i have been looking in to, to give it a chance of living
the idea was for reliability and driveability of most importance, but i will miss the anti lag so don't be surprised to hear it again
Old 10-12-2007, 08:16 PM
  #108
DENNIS
DENNIS's Avatar
i was from Ian howells at racetek
Old 10-12-2007, 08:58 PM
  #109
NEEDFORSPEED
yeah get it on 'just incase you decide to use it' lol. itl be back! not sure now had a peter g on order but think maybe one of mike r now. not 100% youd be a star if you could do that for me!il pm the opart numbers n il stick you on my christmas card list!
your inlet looks very well made they look so much neater dont they!
Old 10-12-2007, 09:01 PM
  #110
rapidcossie
have you looked at a heat sink on the lambda sensor? I run one on my wideband and it might make yours last a bit longer?
Old 11-12-2007, 08:39 AM
  #111
gareth589
gareth589's Avatar
Just read all the postings on your cossie. Being honest a lot of it is way above my station and understanding. However you have a truly stunning car amd from all the effort and hard work you have put in to this, I hope you get the results you want.
The people that are being catty well as I say, do one if you dont like
On the money side to do what you have done to your engine what would be the cost with labour as am looking in march to have my engine upgraded and would like 400bhp but not with it going wrong every 5 mins.
Regards
Gareth
Old 11-12-2007, 07:32 PM
  #112
DENNIS
DENNIS's Avatar
Thank you for your kind words..
as for the engine build, i have sent you a pm..
cheers
Old 12-12-2007, 01:15 PM
  #113
Rippers
Monte Geek
Rippers's Avatar
Nice work
Old 21-12-2007, 09:16 PM
  #114
DENNIS
DENNIS's Avatar
well i have all the parts back from dynamic balancing and will hopefully be rebuilding it next week ..
i am also 80% there with the new clutch set up.. capable of 800 + BHP but as nice to drive as a std ford item
Old 22-12-2007, 03:00 AM
  #115
NEEDFORSPEED
more info pleeeese!! jap most probably!!! i will pay for your information!!lol
Old 23-12-2007, 09:05 AM
  #116
DENNIS
DENNIS's Avatar
more info on ??
Old 23-12-2007, 09:26 AM
  #117
NEEDFORSPEED
clutch please sounds too good to be true!!lol
does this sound rite to you for the coil dwell info?
Batt Voltage Dwell time
8 Volt 7 ms
10Volt 5.5 ms
12 Volt 4.5 ms
14 Volt 4.0 ms
16 Volt 3.0 ms i presume yours will be the same aswel so may of saved you a job
Old 23-12-2007, 02:43 PM
  #118
Billy_RS
Billy_RS's Avatar
Hows this going now Dennis?
Looks like its going to be super clean
Where did you get your bits electroplated, good idea
Old 27-12-2007, 08:03 PM
  #119
DENNIS
DENNIS's Avatar
8 Volt 7 ms
10Volt 5.5 ms
12 Volt 4.5 ms
14 Volt 4.0 ms
look`s good, but i will check to make sure ... just need to find five minutes
as for the clutch ...
a preview...
unfortunately this has proven to be very expensive, as i have had to make major changes to the flywheel,gear box and operating mechanism and the clutch alone retails at £1000.00
but for the results, i feel it`s worth it and should be a fit and forget item.
i now have all the bits back and have got as far as fitting the crank with the ARP main stud kit and modding the block to accept the new knock sensor where it should be !!!
pics soon ..
Old 27-12-2007, 08:05 PM
  #120
DENNIS
DENNIS's Avatar
i will put the number up soon
Quick Reply: My Escort Cosworth, now on the road again ...
