EDAN Escort S2 Turbo.Update,03/04/11 reverse charge carrier fitted
#1323
awesome, i spent the afternoon today reading this thread, and it is an awesome car you have there mate! a lot of love and attention has gone into it , and it has turned out truly awesome! you should be proud and i for one am slightly envious of you to have such talent to work so much on the car yourself! i wouldnt kno where to start doing something like that! excellent mate, truly excellent!!
craigo
craigo
#1335
holy crap... i just looked thru this whole thread the last two hours... this is the most incredible restoration project i have ever seen man.. really makes me dream about my own rs..
keep up the good work..
#1337
At last i have some pictures of the steering wheel fitted ,having a bit of trouble with the horn push though ,has any one else come across this ,it seems to big for the wheel and also the horn wants to go off all the time ,think i may have something touching behind it .Even when placing the horn push to the wheel the horn goes off and if you turn the wheel goes off again
#1343
Redumbdancy
Looks cracking - wheel matches superbly - finishes off the interior well, i seriously don't think you'll be able to find another thing to change in the interior - im hoping you'll prove me wrong!
#1352
Been working on the bonnet for a fair few hours today doing the filler work ,about 90% there with it now ,here are some pictures .
First coat of the fiber/filler mix rubbed down and the first coat of filler applied.
More block sanding on this side
More filler applied and guide coated in the low areas.
2nd skim of filler on the n/s.
Getting there ,attacking the badge area
Few more low spots getting dealt with.
Thats all i wanted to do today ,been on it long enough will get some more done soon as its really close to primer now
Oh sorted the horn issue (thanks for the advice Puss)
#1355
excellent work dave!!! i wanted to get those exact bonnet pins for mine when i had the bonnet inncident but didnt quite go through with it for some reason...
cant wait to start work with mine again...engine is slowly coming together for mine now...nearly everythign is here for rear disc conversion and ill start tidying up the underside when im on holiday next
bassboy
bassboy
#1357
bassboy
bassboy
