EDAN Escort S2 Turbo.Update,03/04/11 reverse charge carrier fitted
#2284
Originally Posted by Twins
Originally Posted by mercury grey minter
Very nice,but when are you gonna sort out your PASSENGER SIDE REAR QUATER PANEL?????? ![Big Grin](https://passionford.com/forum/images/smilies/icon_mrgreen.gif)
#2291
Cheers guys ,ok time for another update ,today i started to get the filler into the doors.
First stage was to get the paint off the doors where i wanted to fill.
![Name: audidoorhandles058.jpg
Size: 52.5 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/99515d1501884623-edan-escort-s2-turbo-update-03-04-11-reverse-charge-carrier-fitted-audidoorhandles058.jpg)
![](https://img.photobucket.com/albums/v481/TWINSEDAN/danoct04/audidoorhandles060.jpg)
Next stage was to get a fiberglass mix over the area that was welded to fill any pin holes etc ,excess was used to fill other sections in the door, so there was no waste.
![Name: audidoorhandles059.jpg
Size: 74.9 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/99516d1501884623-edan-escort-s2-turbo-update-03-04-11-reverse-charge-carrier-fitted-audidoorhandles059.jpg)
![Name: audidoorhandles061.jpg
Size: 60.0 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/99517d1501884623-edan-escort-s2-turbo-update-03-04-11-reverse-charge-carrier-fitted-audidoorhandles061.jpg)
This was then rubbed down roughly with 40 grit.
![Name: audidoorhandles062.jpg
Size: 64.6 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/99518d1501884623-edan-escort-s2-turbo-update-03-04-11-reverse-charge-carrier-fitted-audidoorhandles062.jpg)
![Name: audidoorhandles064.jpg
Size: 54.7 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/99519d1501884623-edan-escort-s2-turbo-update-03-04-11-reverse-charge-carrier-fitted-audidoorhandles064.jpg)
Now this was keyed the first coat of filler was applied.
![Name: audidoorhandles063.jpg
Size: 68.1 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/99520d1501884623-edan-escort-s2-turbo-update-03-04-11-reverse-charge-carrier-fitted-audidoorhandles063.jpg)
![Name: audidoorhandles065.jpg
Size: 51.6 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/99521d1501884623-edan-escort-s2-turbo-update-03-04-11-reverse-charge-carrier-fitted-audidoorhandles065.jpg)
This was then guide coated ready to be rubbed down.
![Name: audidoorhandles066.jpg
Size: 74.5 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/99522d1501884623-edan-escort-s2-turbo-update-03-04-11-reverse-charge-carrier-fitted-audidoorhandles066.jpg)
![Name: audidoorhandles067.jpg
Size: 90.1 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/99523d1501884623-edan-escort-s2-turbo-update-03-04-11-reverse-charge-carrier-fitted-audidoorhandles067.jpg)
![Name: audidoorhandles068.jpg
Size: 82.7 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/99524d1501884623-edan-escort-s2-turbo-update-03-04-11-reverse-charge-carrier-fitted-audidoorhandles068.jpg)
![Name: audidoorhandles069.jpg
Size: 108.0 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/99525d1501884623-edan-escort-s2-turbo-update-03-04-11-reverse-charge-carrier-fitted-audidoorhandles069.jpg)
![Name: audidoorhandles070.jpg
Size: 68.8 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/99526d1501884623-edan-escort-s2-turbo-update-03-04-11-reverse-charge-carrier-fitted-audidoorhandles070.jpg)
More soon
More soon
![Banana](https://passionford.com/forum/images/smilies/banana_dance.gif)
#2295
Fleet Manager
u gonna have them done for rsoc on thesday?????
oh and where would you reccomend to take my rst to be set up?
i was goin to use engine advantages but a mate of mine had his car done and the fule was so lean he nearly lost his engine
i was thinking jam sport but dont want to travel all that way
#2301
isn't it
sorry mate, bt not a fan of how thats coming out. dont like the shape of the handle recess at all, doesn't fit the shape of the car. the idea is good, like i sed, i looked at montego ones for mine, but they have to be something squarer, off a a similar shaped car, flow with the press lines etc. and these just dont seem to fit the look of a mk4 escort.
#2302
#2303
This is going to look amazing mate!
I might do a door handle conversion to my fiesta as my doors are in need of filling due to car park dents so this coiuld be just the job for me
#2304
Also you may have seen my m8 out in his Margenta Saph cossie he lives in Burnham
#2305
Originally Posted by sidewayz
coming along nicely, never used guide coat on filler before
Looking good m8
![Smokin](https://passionford.com/forum/images/smilies/icon_smokin.gif)
#2307
Alan s1- to be honest mate, i dont recall seeing a magenta saph around that area and im normally over that way everyday anyway. yea field are on the industrial estate
#2309
they look better then the SHITE they have standard, i like them
#2310
Grey Mk4 Early XR3I
looking like a proper job mate
also in regards to some people not using a guide coat on filler
if u dont you will never fill every single pin hole caused by sanding down the filler
guide coat is jus basically black spray used as a dust coat it shows up high and low spots also makes fillering 10 times easier as u can see where you need to fill with a second skim ect
back on topic they are gunna look smart as mate hurry up :P
#2312
isn't it
i duno, they might look better painted?
