EDAN Escort S2 Turbo.Update,03/04/11 reverse charge carrier fitted
#5166
I'm guessing that you'll be painting the 'reverse charge carrier' ![Wink](https://passionford.com/forum/images/smilies/icon_wink.gif)
On autospecialists site I think it would be helpful if you could enlarge the picture of them fitting this kit to their S2 as I find it hard to visualise how it fits in the smaller pictures, just a thought. In relation to their standard single pass cooler this one looks HUGE.
Look forward to taking a look at this fitted to yours at central day. Bring it on! lol![ban-split](https://passionford.com/forum/images/smilies/ban-split.gif)
#5176
Ok spent the last couple of afternoons fitting the new bits on ![Big Grin](https://passionford.com/forum/images/smilies/icon_biggrin.gif)
Stripped off the old bits ,got a new exhaust gasket and some turbo water pipe washers,also changed the heat wrap to black.
Old unit off ,still perfectly good mind you
![Name: E889DAN363.jpg
Size: 1.56 MB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/100312d1501884623-edan-escort-s2-turbo-update-03-04-11-reverse-charge-carrier-fitted-e889dan363.jpg)
![Name: E889DAN366.jpg
Size: 1.49 MB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/100313d1501884623-edan-escort-s2-turbo-update-03-04-11-reverse-charge-carrier-fitted-e889dan366.jpg)
Manifold showing copper gasket
![Name: E889DAN367.jpg
Size: 1.53 MB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/100314d1501884623-edan-escort-s2-turbo-update-03-04-11-reverse-charge-carrier-fitted-e889dan367.jpg)
Old and new together
![Name: E889DAN369.jpg
Size: 1.62 MB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/100315d1501884623-edan-escort-s2-turbo-update-03-04-11-reverse-charge-carrier-fitted-e889dan369.jpg)
![Name: E889DAN372.jpg
Size: 1.55 MB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/100316d1501884623-edan-escort-s2-turbo-update-03-04-11-reverse-charge-carrier-fitted-e889dan372.jpg)
New one wrapped
![Name: E889DAN379.jpg
Size: 1.52 MB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/100317d1501884623-edan-escort-s2-turbo-update-03-04-11-reverse-charge-carrier-fitted-e889dan379.jpg)
![Name: E889DAN380.jpg
Size: 1.47 MB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/100318d1501884623-edan-escort-s2-turbo-update-03-04-11-reverse-charge-carrier-fitted-e889dan380.jpg)
Turbo nearly done
![Name: E889DAN381.jpg
Size: 1.59 MB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/100319d1501884623-edan-escort-s2-turbo-update-03-04-11-reverse-charge-carrier-fitted-e889dan381.jpg)
Got the cooler out next and fitted the fans
![Name: E889DAN383.jpg
Size: 69.9 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/100320d1501884623-edan-escort-s2-turbo-update-03-04-11-reverse-charge-carrier-fitted-e889dan383.jpg)
![Name: E889DAN385.jpg
Size: 1.50 MB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/100321d1501884623-edan-escort-s2-turbo-update-03-04-11-reverse-charge-carrier-fitted-e889dan385.jpg)
![Name: E889DAN386.jpg
Size: 1.62 MB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/100322d1501884623-edan-escort-s2-turbo-update-03-04-11-reverse-charge-carrier-fitted-e889dan386.jpg)
Very good instructions came with the kit,i sorted the relevent brackets out for the rad as it has to move across to accomadate the cooler
![Name: E889DAN407.jpg
Size: 1.16 MB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/100323d1501884623-edan-escort-s2-turbo-update-03-04-11-reverse-charge-carrier-fitted-e889dan407.jpg)
![Name: E889DAN408.jpg
Size: 1.23 MB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/100324d1501884623-edan-escort-s2-turbo-update-03-04-11-reverse-charge-carrier-fitted-e889dan408.jpg)
![Name: E889DAN409.jpg
Size: 1.05 MB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/100325d1501884623-edan-escort-s2-turbo-update-03-04-11-reverse-charge-carrier-fitted-e889dan409.jpg)
![Name: E889DAN410.jpg
Size: 1.13 MB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/100326d1501884623-edan-escort-s2-turbo-update-03-04-11-reverse-charge-carrier-fitted-e889dan410.jpg)
Old cooler with new
![](http://img.photobucket.com/albums/v481/TWINSEDAN/nov%202010/E889DAN387.jpg)
![Name: E889DAN388.jpg
Size: 1.53 MB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/100327d1501884623-edan-escort-s2-turbo-update-03-04-11-reverse-charge-carrier-fitted-e889dan388.jpg)
Cooler bolted up, rad and hoses to tighten up,i had my brackets done black as they come in a brushed silver effect
![Name: E889DAN393.jpg
Size: 1.56 MB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/100328d1501884623-edan-escort-s2-turbo-update-03-04-11-reverse-charge-carrier-fitted-e889dan393.jpg)
![Name: E889DAN394.jpg
Size: 1.55 MB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/100329d1501884623-edan-escort-s2-turbo-update-03-04-11-reverse-charge-carrier-fitted-e889dan394.jpg)
![Name: E889DAN396.jpg
Size: 1.53 MB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/100330d1501884623-edan-escort-s2-turbo-update-03-04-11-reverse-charge-carrier-fitted-e889dan396.jpg)
Air filter on in slightly new position
![Name: E889DAN392.jpg
Size: 1.51 MB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/100331d1501884623-edan-escort-s2-turbo-update-03-04-11-reverse-charge-carrier-fitted-e889dan392.jpg)
New elongated top water hose on,as rad is moved across
![Name: E889DAN397.jpg
Size: 1.52 MB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/100332d1501884623-edan-escort-s2-turbo-update-03-04-11-reverse-charge-carrier-fitted-e889dan397.jpg)
Just waiting on my reverse charge carrier as i have had the standard hole flushed as i run an act sensor in its place ,this will be done magic black when done ,also did my jubilee clips black that were replaced
![Name: E889DAN398.jpg
Size: 1.57 MB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/100333d1501884623-edan-escort-s2-turbo-update-03-04-11-reverse-charge-carrier-fitted-e889dan398.jpg)
![Name: E889DAN401.jpg
Size: 1.51 MB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/100334d1501884623-edan-escort-s2-turbo-update-03-04-11-reverse-charge-carrier-fitted-e889dan401.jpg)
![Name: E889DAN403.jpg
Size: 1.52 MB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/100335d1501884623-edan-escort-s2-turbo-update-03-04-11-reverse-charge-carrier-fitted-e889dan403.jpg)
![Name: E889DAN406.jpg
Size: 1.51 MB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/100336d1501884623-edan-escort-s2-turbo-update-03-04-11-reverse-charge-carrier-fitted-e889dan406.jpg)
Fans wired in
![](http://img.photobucket.com/albums/v481/TWINSEDAN/nov%202010/E889DAN411.jpg)
Just need to bleed system ,when pipe work come back
New one wrapped
Turbo nearly done
Old cooler with new
Fans wired in
#5179
the attention to detail is immense the little things like braided loom for the fans! i think im going to need the twins treatment to my s1! Just out of interest why the recent performance upgrades im sure the car does not see any hard use?
#5180
Spanner monkey
Congrats on the new purchase
#5181
Looks better and better mate.
How do you keep you front panel pristine looking?! Mine was new and painted but has battle scars from bumper removal/ cooler/ rad/ turbo refits etc etc lol
Stunning. Have to take it for a little drive once she's run up. Weathers set to hold out as it for a bit yet
#5186
hi gary how are you hope things are well? it was a bargain I even told dave he was selling it far too cheap! pm me your number mate!
