My escort cos winter tidy up
Old 28-02-2007, 11:37 PM
The Youth.
The Youth.'s Avatar
Default My escort cos winter tidy up
After I had returned from the ring in sept 06 my power steering rack failed so over xmas I removed it and replaced it, whilst it was out I took the oppertunity to degrease/ clean the bottom of the engine bay and crossmember, this then led to my to decide to remove the front running gear to get it all powder coated / painted
I painted the hubs by hand as I wanted the minimium thickness on the front of the hub to reduce any wheel wobble so on the back I used hammerite smooth and a spray version of it on the front face, I have access to a sand blaster so prepping them was made easy.
the bottom suspension arms were painted
the hub carriers and anti roll bar were powdercoated
parts painted /prepped
refitting begins
the caliper brackets were powdercoated and the calipers painted by hand in matching paint
I painted the disks in high temp paint after blasting them to reduce the chance of them rusting
the front is nearly finished now, just waitng for the brake pipe brackets to come back from the powdercoaters then the wheels can go back on.
whilst waiting for this tonight I started degreasing the offside floorpan, it is coming up like new!!
will post some pics of it tomoz
next winter I will remove the rear beam and paint/powdercoat the complete back of the car
steve
Old 01-03-2007, 06:58 AM
JezSierra
happy with that
JezSierra's Avatar
looks good mate
Old 01-03-2007, 07:29 AM
maxest
maxest's Avatar
Very nice!
Old 01-03-2007, 07:49 AM
Sticky.
Sticky.'s Avatar
Looks good mate
Old 01-03-2007, 07:57 AM
alanfordtw-15
alanfordtw-15's Avatar
cool i must do that with mine if i were you id do the back end now aswell such an easy job and rewarding reults for the rest of the year. only problem is keeping it clean
Old 04-03-2007, 12:43 PM
redrsmk5
redrsmk5's Avatar
Hi mate, what are you using to degrease the floor pan? Your work looks very good!! god i wish i had a garage!
Old 05-03-2007, 12:19 AM
The Youth.
The Youth.'s Avatar
Just using some normal deagreasant from the motor factors it's ok, but I am going to buy some propper"gunk" for the passengers side as that stuff is miles better than what im using.
steve
Old 05-03-2007, 01:08 AM
Brian
Brian's Avatar
Brian
tonicosworth
Ford Escort RS Cosworth
31-10-2015 08:40 AM
Chopshop85
12-09-2015 06:42 PM
imnoteasy
07-09-2015 09:26 PM
Ade
Alloy wheels and ICE for sale
07-09-2015 05:06 PM
Bighandsuk
02-09-2015 05:23 PM
Quick Reply: My escort cos winter tidy up
