Audi 20v Turbo powered Rover 25 (some new pics page 3)
#161
Just a little update...
It now has 6 pots
More power is needed so new injectors, turbo exhaust manifold and Pectel T2 ecu
Turbo and manifold.. Water and oil drain sorted..
New and original manifold..
Original pulley converted to 36-1
Mocking up crank sensor..
Cam sensor, looks familiar
YB air temp sensor..
getting there..
It now has 6 pots
getting there..
#167
really nice car this is,
iirc i see this at castle combe either this year or last year,
if it is the right car it snapped a track rod end and had a little off?
#170
what manifold and turbo did you go for? the jabba ones are notorious for cracking and the ihi turbos for warping the exhaust housings. I'm in the process of changing mine due to a cracked manifold but i dont have much hope of it asting to long tbh but we'll see i suppose lol
#171
Been a long time.. The IHI turbo failed mid 2010 and at that I couldn't be arsed with it so into storage it went. Fast forward to Dec 2016 and I get an email asking if I still have the car and if so can it be bought. That email made me think about the car and instead of selling I have decided to fix it up and make it a more focused track car. The car was fast on track but the suspension was tarmac rally stuff so it didn't handle the way I wanted. Anyhow a plan has been put together heres the plan:
Rebuild the engine with new pistons and crank to give 2 litre capacity (up from 1800cc), IHI ball bearing turbo binned in favour of a TD05 18G, Quaife ATB diff being swapped for a gripper plated, stiffer engine mounts, Dunlop DZ03 tyres, new brake discs on the front, vented rear brake kit and a set of AST 2 way coil overs with canisters with much stiffer poundage springs (as per the ZR race cars). Hopefully this will all result in a different handling animal. Pics will follow but it looked real sad a couple of weeks ago..
#172
Will be good to watch it come back to life, 400 bhp plus is quite easy on these engine now, I believe?
#174
I used to do a lot of track days with Trevor Reeves who won the rallycross world champ, he taught me a lot and I had my first off with him in the car at high speed....he ran a mk1 gold with a trick 20v and I remember him bowing away a well driven f40 at good wood, that had 350 / 400 20v. His 70 yr old dad, Maurice used to peddle it well too.
JoeyBoyden
04-01-2024 02:36 PM
steerfromdarear
28
29-01-2016 06:14 PM
