My 3door cosworth project.* UPDATE* BREAKING
Old 22-12-2010 | 09:02 PM
  #2641
J1mbo's Avatar
J1mbo
B1mbo
What power you looking for Ron?
Old 22-12-2010 | 10:37 PM
  #2642
Ken_ZS's Avatar
Ken_ZS
yea it is rcs cables, made us up some really nice silicon looking blue cables for our topolino dragster. il get on it Ron
Old 23-12-2010 | 07:27 PM
  #2643
Miller 3's Avatar
Miller 3
about 450ish bud
Old 23-12-2010 | 07:41 PM
  #2644
Danny @ Enhanced Performance's Avatar
Originally Posted by miller3
about 450ish bud
Whats the engine spec going to be dougy??
cheers danny
Old 23-12-2010 | 07:49 PM
  #2645
Miller 3's Avatar
Miller 3
that fig may be a tad generous mate but Vince at cr is going to turn Ron's t34 in to a t38,
Old 23-12-2010 | 07:51 PM
  #2646
Jay,'s Avatar
Jay,
Sponsor
spoke to vince today he recons it will do 450
Old 23-12-2010 | 08:20 PM
  #2647
Miller 3's Avatar
Miller 3
Old 23-12-2010 | 09:05 PM
  #2648
Weve used a few of vinces t38s and they can just about on the right engine but you will have to ring the shit out of it witch wont be reliable..
Imo you should run 2.2 bar peak 2 bar held for it to last and that will see around the 420 hp mark and around the same torque but will need valve pockets and a nice inlet cam with the ports and throats cleaned up,also as ronnie will need to rev it the cam timing will need to be done to suit as otherwise it wont want to rev ..
cheers danny
Old 23-12-2010 | 10:42 PM
  #2649
J1mbo's Avatar
J1mbo
B1mbo
On one of our good spec engines, waples head, cam, the t38 does 440-450bhp at 26-27 psi and 100 percent reliable IMO, it will need a slightly ported head for this though Ron, they don't make brilliant torque though around 360lbft on our super flow
Old 23-12-2010 | 10:43 PM
  #2650
pimp-daddy's Avatar
pimp-daddy
Your the man....
Old 23-12-2010 | 11:21 PM
  #2651
I d like to see them graphs??
The only time weve ever seen them power figs at a held boost pressure is on a tt t38 but even then with much better torque than that..
What spec engine is that jimbo??why so lame on torque??
cheers danny
Old 24-12-2010 | 07:27 AM
  #2652
turbotoaster's Avatar
turbotoaster
maybe j1mbos talking about the tt t38 as he doesnt state that its vinces t34 modified to t38, im sure he will fill us in shortly.
Strange about the torque, but saying that danny, your peaking at 2.2bar, if his doesnt peak then thats only 1.86bar
Old 24-12-2010 | 08:01 AM
  #2653
J1mbo's Avatar
J1mbo
B1mbo
Course, I'll get plenty of graphs,
Just nice ported head, cam on inlet, 4x4 manifolds,
And yes, vinces cr turbos t38
They just are not a torquey turbo really,I'll get graphs for you later
On a proper spec engine with long rods, wrc manifold, st inlet, cps, ported head, pair of wild cams. It gave 460bhp and 430 lbft fr a hill climb car, that was high comp too.
Old 24-12-2010 | 08:29 AM
  #2654
carlo's Avatar
carlo
i had one of they engines from yous jimbo was great lasted 6 years between charlie shaw & me then got a freshen up now its in martynhomers 3 door still going edited to ad 6 very hard years
Old 24-12-2010 | 09:48 AM
  #2655
J1mbo's Avatar
J1mbo
B1mbo
that took some abuse too
Old 24-12-2010 | 03:38 PM
  #2656
I was talking about the turbo being unreliable not the engine and sorry but i dont believe you will get 450 hp at 26 psi!!!
As for torque weve seen well over 400 lbft on superflow and dd rr many times but as said thats with 2.2 bar peak and the right inlet cam..
cheers danny
Old 24-12-2010 | 03:56 PM
  #2657
J1mbo's Avatar
J1mbo
B1mbo
It's 26 or 27 at 7k makes the power, didn't get graphs so I'll get some after xmas I totally forgot, but I'll show you them, just shocking memory
Old 24-12-2010 | 04:54 PM
  #2658
Gazzonator's Avatar
Gazzonator
Gary Krishna
I don't see why the CR T38 can't make that power on a good engine IMO.
I ran a Universal Turbos T38 on mine (can't see it being much different tbh) and at 28 psi held made 450 bhp on the nose with 390 ib/ft of torque. Ok, so the torque wasn't great but it still made some nice numbers!
It was dead reliable too, it got a beating at every opportunity for well over a year and a half and is still going just as strong on my mates car!
Old 24-12-2010 | 05:06 PM
  #2659
Them two turbos make totally different power mate but in all fairness its totally down to the cams and cam timing ime..
Cossie4i runs the same turbo as you on a std 2wd bottom end with a small port head and just a ab07 inlet cam and has now seen 480 hp and 470 lbft iirc all be it on a very cold day but because everything is specced well and mapped well its power is much larger than yours for example and even on a hot day will do 450 hp
Im not saying you cant get 450 hp out of the cr t38 im just saying you will need to ring the boost out of it...
cheers danny
Old 24-12-2010 | 05:15 PM
  #2660
Gazzonator's Avatar
Gazzonator
Gary Krishna
I though Cossie4i had the Turbo Technics jobbie on his one?
Mine was the one with that looks like a T34.
Mine was also on standard cams.
Old 24-12-2010 | 09:10 PM
  #2661
Your right mate yes i miss read and thought you said tt t38..
What is the rest of your spec and who done it all for you??
cheers danny
Old 24-12-2010 | 10:48 PM
  #2662
Gazzonator's Avatar
Gazzonator
Gary Krishna
cheers danny
Alright mate, the spec wasn't anything special if I'm honest.
UT T38, grey injectors, fully rebuilt and ported head, standard cams, totally standard bottom end, coil pack, proper loom and all the usual gubbins (500 cooler, exhaust etc).
The cylinder head was done by Cylinder Head Developments but I put it all together myself.
Old 24-12-2010 | 11:06 PM
  #2663
BRAMMER's Avatar
BRAMMER
The UT T38 i had on mine made 441/450 with an outside temp of +24 degree in June this year - 8:1cr, 26mm ported head, std cams, Siemens 55's that were maxed
I would have thought Ron would have gone for a different unit, using mine on the road it was better than most thought but i'm not sure about a track, i would have gone for a new GTX3071R turbo and strong build with decent cam.
Old 24-12-2010 | 11:11 PM
  #2664
You done well getting that power mate,what rollers was that on??
You are spot on with your spec there mate would be alot better!!
If i had my way i was going to do gt3071.82 sep w/g my inlet cam and a hart plenum etc..
Would of done 450/450 at 2.2bar peak and 2 bar held no probs
cheers danny
Old 26-12-2010 | 07:54 AM
  #2665
GaryHurn's Avatar
GaryHurn
danny get me 450/450 lol
Old 16-01-2011 | 04:56 PM
  #2666
RONNIE AMIS's Avatar
RONNIE AMIS
been doing bits and pieces on the car, first race is only two months away so best start cracking.
carbon doors fitted, will be wrapping them gloss black for now.
wheel well has been cut out
also making up brackets for the fuel cell to fix on to
doug has been cutting the loom out, looks like spaghetti junction
started a new job two weeks ago and their is a little corner full of paint etc, so thought it'd be rude not to paint my front bumper as last year it was just quickly toshed over satin black
been rubbing it down in between jobs
repaired a crack on the top,
Old 16-01-2011 | 04:58 PM
  #2667
Steve the Plumber's Avatar
Steve the Plumber
The original Rouge Trader
Getting there slowly Ron,
Old 16-01-2011 | 05:00 PM
  #2668
COCHYN's Avatar
COCHYN
Yup, really looks like shit at the mo Ronnie But will be awsome no doubt
What's happening with the engine?
Old 16-01-2011 | 05:05 PM
  #2669
gus's Avatar
gus
i cant believe the difference in them doors
cant wait to see it done
cheers for those instructions today (she peaked at 10psi on the way home)
Old 16-01-2011 | 05:53 PM
  #2670
Brian's Avatar
Brian
Brian
Old 16-01-2011 | 07:08 PM
  #2671
cossie daz's Avatar
cossie daz
looking good ron , all the best with the coming season
Old 16-01-2011 | 09:53 PM
  #2672
Sticky.'s Avatar
Sticky.
Nice update Ronaldo.
Old 16-01-2011 | 09:55 PM
  #2673
Staffi's Avatar
Staffi
Keep it coming Ron, good luck for the new season too when it starts.
Ron,
Off topic, doesn't Ollie Clark race in TA anymore with the Gobstopper??
Old 16-01-2011 | 10:06 PM
  #2674
Luca's Avatar
Luca
Lukesville
Wooooo progress on that mate, but no Krispy Kremes???
Old 16-01-2011 | 10:08 PM
  #2675
Miller 3's Avatar
Miller 3
RCM had a year out Pete as the developing there new car
Ron think we need to crack on a bit more with the car, it will soon come around
you heard any more from Joe?
I recon the new decals should be the same as last year just orange too
Old 16-01-2011 | 10:10 PM
  #2676
Miller 3's Avatar
Miller 3
Get ya ass over next w/end and il get the dog nuts in
Old 16-01-2011 | 10:11 PM
  #2677
Puss2's Avatar
Puss2
Formerly know as Puss
Nice work Ron.
Old 17-01-2011 | 05:02 AM
  #2678
MARCOSWORTH's Avatar
MARCOSWORTH
Good Ron
Old 17-01-2011 | 05:45 AM
  #2679
Gav Diamond's Avatar
Gav Diamond
Looking great bud
Hope to actually make it to some events to see you out this year
Old 17-01-2011 | 12:08 PM
  #2680
Lo@der's Avatar
Lo@der
Passionford Thread Killer
Is that bumper for me Ron ??
:-p
Quick Reply: My 3door cosworth project.* UPDATE* BREAKING
