MY XR3 23 july 2006
Old 28-02-2006, 06:15 PM
rambo11
rambo11's Avatar
Default MY XR3 23 july 2006
LOOK WHAT I FOUND when i took the rear spat off gutted !
Old 28-02-2006, 07:00 PM
mondeomark
mondeomark's Avatar
Location: Newcastle-under-Lyme, Stoke-on-Trent, Staffordshire
OUCH!!!!!!!!!!!!!
Old 28-02-2006, 09:11 PM
markc
markc's Avatar
nout some metal and a welder cant fix
Old 01-03-2006, 09:14 AM
Not the end of the world ,get it fixed and it will be better than new
Old 01-03-2006, 10:04 AM
MikeyXR2i
MikeyXR2i's Avatar
Nothing really, not for the age of the car. Find one thas been out in all weathers for 20 odd years, be no arch left.
Old 01-03-2006, 10:15 AM
Willem
Willem's Avatar
been there 2 times before and am doing it for the 3rd time now, and I'm just a hobbywelder, but I find it the worst thing to do, your luck is that its an escort, little more space to work than a fiesta
Old 01-03-2006, 11:10 AM
Mike C
The Special One
Mike C's Avatar
nasty, get it sorted, lol
Old 02-03-2006, 10:55 PM
black r3
black r3's Avatar
mate your worried about that i just restored my 1980 xr3 & i still aint happy with it!!
Old 04-03-2006, 03:10 PM
rambo11
rambo11's Avatar
Default this it it today
half way there! bast...d found another hole
dread to tink wats on the other side
Old 04-03-2006, 03:22 PM
rambo11
rambo11's Avatar
ive welded the outer arch on now just got to tac them both together now so its doubled skinned like it should be, luckally the welding is still coverded by the rear spat
Old 04-03-2006, 09:01 PM
MikeyXR2i
MikeyXR2i's Avatar
Mate thas a decent looking repair has to be said. Have u used underseal there? If so what one?
Old 04-03-2006, 09:11 PM
Munch
Mr. Sparkle!
Munch's Avatar
you was moaning about nothing really
Old 04-03-2006, 10:53 PM
rambo11
rambo11's Avatar
ive not undersealed yet gto to drill a hole so i can put the gromet back in
the welding was bad untill i ground it off
Old 04-03-2006, 10:57 PM
mercury grey minter
mercury grey minter's Avatar
An escort that needs welding,never heard of that before.lol
Old 04-03-2006, 11:25 PM
grunter
grunter's Avatar
more like a ford that needs welding neva heard that before lol
Old 04-03-2006, 11:35 PM
MikeyXR2i
MikeyXR2i's Avatar
Don't bother drilling a hole for the grommet, thas why it rusted to start with, the metal cap that was in there rusts and transfers it to the inner arch around the hole.
Old 25-04-2006, 06:05 PM
rambo11
rambo11's Avatar
got carryed away with the underseal and hamerite
Old 25-04-2006, 06:12 PM
xr3-keith
xr3-keith's Avatar
looking good
keep up the good work
Old 27-04-2006, 06:27 PM
rambo11
rambo11's Avatar
cheers
Old 07-05-2006, 06:31 PM
rambo11
rambo11's Avatar
this is it today 7 may 2006
found some brand new adjustable rear torsion arms down wales last week so ive managed to put some of the back end to gether now at last
Old 07-05-2006, 07:02 PM
tim10_10
tim10_10's Avatar
What set up are you using up front? Are you using adjustable track control arms?
Old 07-05-2006, 07:03 PM
rambo11
rambo11's Avatar
yes that is is the plan when i get there
Old 07-05-2006, 07:05 PM
tim10_10
tim10_10's Avatar
Ive done the same on mine adjustable tca's and 16i roll bar and cross memeber just needs aligning now, hopefully get sum negative camber then
Old 07-05-2006, 07:08 PM
rambo11
rambo11's Avatar
i couldnt find a good 16i one so i got a s1 turbo instead
Old 07-05-2006, 07:13 PM
tim10_10
tim10_10's Avatar
Typical i could of done with a s1 for mine as the 16i hits the lower apron on the s1 kit. Any way top job keep up the gd work.
Old 07-05-2006, 07:14 PM
rambo11
rambo11's Avatar
cheers mate looks like you nearly done
Old 07-05-2006, 08:06 PM
xr3-keith
xr3-keith's Avatar
Looking Good Rambo11
What else you doing to it
Old 07-05-2006, 10:21 PM
rambo11
rambo11's Avatar
thanks for looking Killer
well the plans are put disc brakes all round the brackets are already on the rear. Hopefully when i come to underseal and paint under the front it wont need any more welding!
.s1 front anti rollbar .Change the 4speed box to my quafe box . then run it till the 1.6 gives up shouldnt take long cause i stopped putting the lead replacement in it now
Old 09-05-2006, 09:34 PM
rambo11
rambo11's Avatar
this is it today when i turned it round to do the front. no exhaust on sounded like a V8 lol
Old 12-05-2006, 09:48 PM
xr3-keith
xr3-keith's Avatar
coming along nicely rambo,
Mine has a big hole in the back box where my best mate and mecanic punched it and now it sounds like a janspeed
Old 18-06-2006, 07:34 PM
rambo11
rambo11's Avatar
had to remove battery tray to tidy up some welding done in the past
before
after
Old 18-06-2006, 11:25 PM
tim10_10
tim10_10's Avatar
Looking good mate you going for a full resto? Really like the sun burst red ones
Old 19-06-2006, 11:45 AM
markc
markc's Avatar
u should really m8ty they are there for waxoyling the sills, just zinc primer everyere b4 hand including the plug and use sealant
Old 19-06-2006, 08:27 PM
rambo11
rambo11's Avatar
i wouldnt say im restoring it i just want it to last another 24 years hopefully still with all its original pannels like its got , im just gona bring the power,brakes,and suspension up to date thanks
Old 19-06-2006, 09:07 PM
MikeyXR2i
MikeyXR2i's Avatar
Nah you can waxoyl in there from inside the car. Take the inner quarter panel out, then slide a waxoyl tube down into the sill.
Old 19-06-2006, 09:56 PM
markc
markc's Avatar
yeah true but it makes it easier to get rigt to the end with the waxoyl gun so u kno every where is covered
Old 22-06-2006, 04:57 PM
xr3-keith
xr3-keith's Avatar
Looking good fella
Old 23-06-2006, 10:42 PM
rambo11
rambo11's Avatar
cheers m8
Old 22-07-2006, 07:19 AM
xr3-keith
xr3-keith's Avatar
Rambo11 whats going on man, no updates for ages
Old 22-07-2006, 01:42 PM
rambo11
rambo11's Avatar
im losing interest in it , been on holiday just picked my new engine up the other day though
Quick Reply: MY XR3 23 july 2006
