Black escort (Netherlands)
My new project.
Specs:
Custom pistons with pockets
Custom rods (h pattern)
Modified head with mechanical lifters
long studded
Steel headgasket
Mongoose exhaust
S.E.C.S. S8 Programmable motor management system
5 bar map sensor
MSD 1000cc injectors
Uprated fuel pump,swirlpot, aeromotive fuelpump.
R&D 6 speed dogbox
Modified Diffs
ALcon 6 paddle clutch
Proflex suspension
Wolf 300 km/u gauge set
Defi gauges
Kevlar/Carbon OMP Seats
4 point sabelt Seatbelts
Radtec Rs500 intercooler with 70mm flange in and 76mm out
Modified inletsystem with 76mm Throttlebody
Custom made Exhaust manifold
F1 Turbo with remote wastegate
Zeitronix Wide band lambda
Fuellab fuel regulator
Wolf ATS 9x18 Alu wheels
Specs:
long studded
Steel headgasket
Mongoose exhaust
5 bar map sensor
R&D 6 speed dogbox
Modified Diffs
Proflex suspension
Defi gauges
Originally Posted by wimwerf
are you sure you've got the biggest air filter
the escos looks wicked.
and we had problems getting a big filter to fit a buddy of mine suggested to place it the otherway around for fun...
But after we did it we left it like this.. it's actually a very good place to have the filter.. loads of air come in at the front
also because the standard intercooler isn't there anymore
Originally Posted by cosworth3d
i would like one of those what is the spec dutch cossie homie
very nice Pim
but the front
have to molest the car to make it fit
ok...but does it fit.
there is nothing that won't fit with some or huge effort..
making some fitting materials..
taken some of the top in the enginebay where the suspension comes in ..
on that have steel rings made with holes so I can bolt it on ..
and it stays on when i take a jump will make pictures when its done..
Originally Posted by CossieGirl
Looks great!
Is the sedan 2wd already sold?
And when is the man with the red sierra coming to this forum?
I think his English is the reason for not showing himself here at PF
Originally Posted by ksa74f/231bhp
Both very nice indeed!!!!!!!!!!!!!!!
Now fitting OMP Kevlar/Carbon seats covered with black/blue leather
4 point Sabelt seatbelts
Already fitted: Wolf 300 km/u cockpit/gauge set.
Autronic installation postponed , will be fitting greys, 5 bar map to have some more power before fitting autronic.
Update
Radtec RS500 intercooler with 70mm in and 76mm pipe out
(pic stolen from radtec website , they have modified the usual pipes for me to this spec, you will soon find out why )
Update
did 12.718 on the 1/4 mile on Lommel yesterday with the current setup... (greys,exhaust,t34)
(without the radtec because they f**ked up the pipes, in and out swapped in size )
thats annoying. and now....you send it back to radtec.
Change it to the correct specifications and send it back to me .. all on there expense... so ..
Finally a company that has real service
Originally Posted by leespiro
hi m8 what colour white is that sierra cossie plz pm me
it got polished (took 1 week to do it completely)... thats all ..
the paint is 18 years old
here is the sheet from the 1/4 mile (escort)..
was a very hot day (32 celcius) so only attempted 1 run...
and without the big intercooler
Originally Posted by Tweety_power
Nice one but reaction
will do a full launch on Landgraaf this weekend, thats a distance I could walk back
btw the other car was a highly tuned Sunny GTI-R (whatever)... quite quick on the first 50 meters or so
Hi Pim
I think you have got your self a nice car (s), and It's gonne be interesting to see
how it goes with the autronic
There were an other box in that picture , with a sticker on from "MSD" ???
Is that stu's work ?
Kind regards Kennert
