New project: 2wd Sapphire Cosworth
#41
New pictures about project: http://www.maxtuned.com/Pictures/Cos_Pro2/
Engine specs:
- new bearings
- new piston rings
- balanced
- blue printed
- high pressure oilpump
- ARP-head studs
- ARP-conrod bolts
- ported head (flows 212hp)
- new followers
- adjustable camshaft pulleys
- Cometic gaskets
- "RS500" cooler
- Haltech E6X
- Garrett GT37
- AMW dumpvalve
- AMW fuel regulator
- AMW wastgate
- MSD 500 cm3 injectors
- "WRC" plenum
- 70 mm throttle body
- 3 " stainless steel exhaust
- K&N airfilter
- Bosch 044 fuelpump
- Setrab oilcooler
- 10 mm / 8 mm fuellines
- BD10 cams
Transmission specs:
- Standard Gearbox (rebuild)
- Alcon 6-padle clutch
- Standard rearaxler
- Redline racing oil and lubricant
If some moderator read this. Could he/she move my topic to restorations, rebuilds and projects forum. Thanks
Engine specs:
- new bearings
- new piston rings
- balanced
- blue printed
- ARP-head studs
- ARP-conrod bolts
- new followers
- Cometic gaskets
- "RS500" cooler
- Haltech E6X
- Garrett GT37
- AMW dumpvalve
- AMW wastgate
- "WRC" plenum
- K&N airfilter
- Setrab oilcooler
- BD10 cams
Transmission specs:
#42
Originally Posted by cozzie4d
Thats looking great mate, finally getting there..
any plans when you want to do the first engine start?
![Clap](https://passionford.com/forum/images/smilies/9c-clap.gif)
Thanks mate. There is still quite much work to do. I think that the first engine start would be about after one month. When I get the car finished it goes straight to dynamometer.
#47
Sounds good, any idea of how much hp you want to get out of it?
#49
Almost ready:
http://www.maxtuned.com/Cossu.jpg
I had problems with the electrics. There was several little faults, but now everything works.
#51
![Banana](https://passionford.com/forum/images/smilies/banana_dance.gif)
It looks GREEEEAAAT! My saph 2wd is white like the first photo... I must get you a photo... I hope you´ll like it !
This is a RESTORATION!!! I try to restore mine, but this is another world!!!
#52
Nice to hear that my project looks good. I love Cosworths so I am sure that your cossie looks really nice aswell.
#53
Now the car is ready.
New pictures about project in Maxtuneds homepage: http://www.maxtuned.com/Pictures/Cos_Pro2/index.htm
We measured 380 hp from backwheels with 1.3 bar. Something 420-430 hp and 460 Nm from engine.
#57
from this standard flat pack shed...
http://www.maxtuned.com/Pictures/Cos_Pro2/1.htm
to this shed sucker...
http://www.maxtuned.com/Pictures/Cos_Pro2/279.htm
nice work bud,that engine looks mint.
09-10-2015 07:38 PM
