Fitted some HIDs, WOW!
Well today I fitted my 5000k H7r HID kit supplied to my by www.xenonsonline.com
It cost £34 and the kit was delivered the day after I ordered them.
They were very easy to fit, it took me less than 30minutes.
Ive taken pics with the lamps set at various heights.
Very pretty box
Anyone thinking of buying a HID kit I strongly recommend Xenonsonline,
Although I chose the standard kit it comes with a full 12mth warranty and the Premium kits come with 24month warranty.
0161 669 5829
Very pretty box
0161 669 5829
That's beam pattern is scattered to fook, don't get me wrong I am sure they are better than standard but I bet they won't align properly at MOT time.
Always the problem with having them in a reflector type headlamp, the bulbs are far too intense so the light just scatters everywhere.
There not so bad, The camera seems to catch the beam more so.
The OE lights were awful.
Deffinately wont be driving with them on in the day time mate.
Going to an MOT station tomorrow to have the beam pattern checked.
they are a good lighting method for sure but very risky to add them on non projector headlights without the above mentioned criteria, and if mates with a MOT tester the there should be no bother really, but lost count of how many cars coming towards me have blinded me as a result of incorrect fitment
Wrong!!!
If there's no washers or self levelling system fitted, they can't be tested so can't be failed...
Aslong as the headlights are aligned properly and give the right pattern they'll pass the Mot with flying colours...
Aside from that, some self levelling suspension systems can't be tested to see if they work as they rely on the vehicle moving to pump the shock absorbers. The Nivomat system, as fitted to some Fords is just such a system. There is no requirement for a road test as part of the MOT, therefore this system can't be tested at MOT.
They could only get you on beam pattern come MOT time and that's only if the pattern is wrong.
I fit HID's to my saff.
They then used too much power and ate my battery, next thing you know it's miss firing, coughing and spluttering. So I took them of and refit H4 bulbs at side of road and she was like brand new again
I know plenty that have failed! MY friends MR Evo THAT HAD FACTORY FITTED XENONS failed due to not having washers/levelling.
Read the lighting section here
http://www.theaa.com/motoring_advice...nges-2012.html
Wrong!!!!
HID headlights can cause dazzle if they are dirty or aimed too high, so they are generally (if light output exceeds 2000 lumens) fitted in conjunction with headlamp cleaning and levelling systems. Where HID or LED dipped beam headlamps are fitted the tester will switch on the headlamps and check the operation of any headlamp levelling and cleaning devices fitted.
The car will fail if a headlamp levelling or cleaning device is inoperative or otherwise obviously defective.
Wrong!!!!
. Vehicles equipped with High Intensity Discharge (HID) or LED dipped beam headlamps may be fitted with headlamp washers and a suspension or headlamp self levelling system. Where such systems are fitted, they must work; however, it is accepted that it may not be possible to readily determine the functioning of self levelling systems. In such cases, the benefit of the doubt must be given. Headlamp washers may work in conjunction with the windscreen washers (when the dipped beam headlamps are switched on) or by a separate switch. HID lamps may be identified by: · taking a few seconds to reach full intensity · having a bluish tinge to the light · having an igniter module/inverter behind the headlamp · having ‘DCR’ marked on the headlamp lens. HID headlamps use high voltage and extra care should be taken when inspecting these items.
check for your self. section 1.7
http://www.motinfo.gov.uk/htdocs/m4s01000701.htm
They fail here all the time if they aren't fitted with levelling/washers. If you retrofit them, you must have those devices fitted (mainly the washers, I don't think they check/can check the levelling).
Unless the rules differ slightly here even though we are part of the UK
Been to my local mot station today and the beam pattern is acceptable. They where a little high which has been adjusted. I was told by the tester that he wouldn't have a problem passing the car with them fitted.
Wrong!!!!
Get your facts right...
If the hid bulbs are fitted into a projector headlight there will be no issue with pattern, if the Mong fitting the bulb can't put a bulb in properly they'll be a pattern issue, standard bulb or hid...
True that, my E46 lights were shocking, funny cross-shape beam pattern, both bulbs were in upside down.
Daft bulb holders though that make you think that the bulbs should be a certain way.
I hate HIDs/Xenons with a passion. I even hate OEM Xenons.
Even cars that have them as standard seem to blind!
Only HIDs I think should be acceptable to fit to a car would be around the 3000k mark so they would appear yellow.
Friend of mine runs an old 5 series with HIDs and I used to abuse him for them. Thing is they are 3000K which are actually yellow. It's actually a pleasure to drive at night! Very bright, you can see things easier, they are easier on the eyes and they don't blind anyone!
Irritating c........
If you're really worried about beam scatter, you can remove the headlights, prize the housings apart (heat in an oven for 20 mins or so to soften the glue to remove the lenses) and then sand and spray paint the reflector bowls a satin colour (most choose black, though satin silver or grey could work - I'd suggest black though on a black car like yours). This will cut down the scatter since there'll be less reflective surface to throw the light around
