zetec engine issue!
zetec engine issue!
my 2.0 silvertop runs perfect but has developed a rattle at 3000rpm ish.
so im taking the engine out to investigae.
first impressions are not good although it looks very pretty!
lots of metal filings on the magnetic sump plug! where the hell is it coming from?
pistons are alloy and stainless steel aint magnetic so im dreading the outcome.
You got lucky! Ive been looking for weeks and cant find one under 100k and that was 250 quid! Somethings a miss with mine coz it was like new inside when i built it. time will tell
here is todays findings, head is off, looks as if its been a tiny bit lean coz of white exhausts valves.
i think it was piston slap.
check out the video below!
https://www.youtube.com/watch?v=boIM...e_gdata_player
im no expert as you know mate but ive just built a cosworth engine and my pistons didnt do that and the cylinders have been honed, i think your cylinders might be worn
Ive run various different systems on it over not many miles. maybe 4k. it may have been a bit rich in the past but last mot it was lean apparently. i think its chewed something up and thats worn bits out with bits in the oil
Not a drop of oil. its never missed a beat til recently. i noticed it was getting harder to start. especially when hot but the starter was heat wrapped so i looked at the engine and it seemed a bit tight to turn. so for whatever reason it looks like its got full of filings and worn it all out. should have it fully stripped tomorrow so we'll see if there is anything obvious. hope its not the oil pump again. already had a zetec destroy itself coz the oil pump was buggered
Well its all stripped and i still have no idea whats happened. it looks like there are metal filings in the oil and they have wrecked everything. the engine was only used for 4000 miles in 6 years. had two oil changes and was perfect when i fitted it. but now its all shagged out. no1 and 4 big ends are chewed up and mains and everything else has wear marks.
Anyway heres a pic of no1 big end shells completely shagged out.
Annoying coz it never ran so well than just before these issues!
they seem to be excellent engines as standard but from my experience they dont seem to like being modified.
bad luck aint the word, its crazy what ive had to go through with the car, debating weather to break car up and get a german car!
not a pressure guage, just light.
https://passionford.com/forum/ford-n...op-engine.html
You'll be fine! £50 and a bit of spannering and you'll be in love again.
may be less agro to get another silvertop, ill see once its out of the focus whether its going to be possible, plus my head is a stage 2 on my silvertop, £200 labour to get it done again.
JoeyBoyden
04-01-2024 02:36 PM
