wet MLR session at combe
seeing as the evos handle so well I was suprised to see some quite steady cornering end in an off.. shit luck at the end.
http://www.youtube.com/watch?v=KKoxsmP5kXY
*** Sierra RS Custard ***
Danny, to be fair its quite hard to adjust to wet track conditions if you havent experienced them before, the drop in grip is just so truely massive if you are on barely treaded tyres that experience is the only thing that can help.
Personally I simply wouldnt be on that track in those conditions if I had only half worn out normal road tyres on, its just pointless, you're never going to make good enough progress so better off saving the petrol and leaving it parked up.
cheers danny
poor little fez! all those spinning evos, even if they are on part worn r888 a little bit of throttle and a bit of oppo and your sorted in stead of shittin it when it comes out and lettin off, point having an evo if u cant drive the fuker properly, wet or not!
I was there with spiky, picked a nice wet slippery one for my first trackday im my pug. Had toyo t1-r tyres on at first but had no grip at all, put the r888's on and was much better. Spiky was running his full wets as was the black 3 door and both had excellent grip
STAFFY OWNER
13-09-2015 08:59 PM
