My 600fwhp Daily Driver
Here you guys can see a few pictures for videos go to http://www.youtube.com/user/FernandoatRSP
Fernando
Fernando
Engine Specs are:
RSP custom turbo kit
RSP custom intake manifold
RSP custom tuning
RSP custom 3 inch exhaust
RSP custom fuel hat with 2 walbros in-tank
RSP custom return fuel system
Ford Racing 80lbs Injectors
CFM billet oil pump
CFM TB65mm
CFM cam gears
CFM stage 3 head
CFM performance shortblock
Clutch Master stage 4
RSP custom tuning
CFM billet oil pump
CFM TB65mm
CFM cam gears
CFM stage 3 head
Engine Specs are:
RSP custom tuning
CFM billet oil pump
CFM TB65mm
CFM cam gears
CFM stage 3 head
RSP custom tuning
CFM billet oil pump
CFM TB65mm
CFM cam gears
CFM stage 3 head
80lb injectors run 100% d.c.???
my car this hp gearbox is broken
1 Post
Pointless mate, you need a totally different tunnel to yours and a different type of gearbox and rear beam compared to a normal Focus. But if you want step by step or tips etc. send a PM to Andrew Gallacher on here... https://passionford.com/forum/privat...=newpm&u=12185
Thanks for the info
been following this thread on focusfanatics.com
good power also isn`t the car runnin race fuel 608bhp,473bhp normal
still can`t argue about the power well done
be nice to see what my own does with race fuel,570bhp/478ftlb
super unleaded,
cheers paul
super unleaded,
cheers paul
Nice job, Fernando. You must have some tuning talent . Btw , you may want to pick up an issue of MM&FF this month . they have a Focus with a rear drive conversion . This kit has been available through Kugel Komponents for 10 years now. It utilizes the cobra irs or 8.8 solid rear axle.
Yes I drive around on pump gas with 470fwhp but is just dump race fuel and change the boost controller to convert this car into a beast
Thanks
Thank you I have being tuning since 2005 mostly Ford's with stock ECU. Once again thanks.
1 Post
Really nice car
But I gotta go with crazycage, I doubt a genuine 600whp. Thats got to be 680 (at least) at the fly, and I dont think 80lb injectors will flow that.
The US cars always seem to make more power for the mods, even with the lower grade fuel. I think its got something to do with the dynos we favour. Europe tend to like Eddie current and the US seem to like Inertia ones.
Whatever, top car
Whatever, top car
I will do a cage soon and about the brakes am looking for options that allow me to put 15" rims so I can fit slicks down the road.
Thanks for all the comments.
You can take 150hp off that figure to compare it to UK BHP. An 80lb injector at 100% duty will make 533hp at the flywheel, or 480 wheels at a BSFC of 0.6.
Rick
Rick
