Escort Turbo But Not What Your Expecting
Hello folks
I have come to do research for an interesting project in the USA
since I'm here, I thought I would show you my primary driver.
Current Interior Modifications:
Rx-7 instrument cluster
Seam welded
WRC style cage soon
Push button ignition
Trunk Gel Cell
custom short shifter
Painless sub-Electric switch/breaker panel
Current Performance Modifications:
Built ,boosted and stripped US (BG Mazda chassis) Escort sedan.
PnP head and round combustion chambers
Matched intake manifold 45mm TB
Ching Chong T-3/T-4 Turbo
DSM stainless 43mm Manifold
Tial 38mm waste
Ching Chow 50mm BOV
TurboXs MBC
GReddy RebicIII fuel controller (2X700cc injectors)
Type 24 "style" Bar and plate FMIC / SS 2.5" charge pipe
1996 UK Escort Cosworth ECC-IV chipped 260hp set for the CVH
Tower braces ,Full urethane, and Lower ties, front and rear
Clutch masters FX400 sprung 6 puck modified clutch disk
Kent CVH37 cam , solid lifters , w/ dual springs
knifed and treated crank
ARP head stud set
Cometic CVH copper head gasket .090"
10 kg flywheel -->lightened OEM unit
Engine
![](http://img.villagephotos.com/p/2007-1/1236955/july-bath-top.jpg)
Front
![](http://img.villagephotos.com/p/2007-1/1236955/image.a2sp.jpeg)
a shot of the car on a clean day ...before I hacked up the front bumper for the snow plow
Seam welded
WRC style cage soon
Trunk Gel Cell
Tial 38mm waste
Ching Chow 50mm BOV
TurboXs MBC
ARP head stud set
Engine
Front
![](http://img.villagephotos.com/p/2007-1/1236955/JKPJN-racetracer.jpg)
The wheels are 14" inch X 5" with a 4 X 100 stud circle. Original equipment for this escort.
Definitely a sleeper ... this car and engine in stock form makes a whopping 88 hp < I am working on fitting a lip for that bumper to
obscure the view of the intercooler a little .
dyno/ rolling road figures of 299 hp 265 tq @18 psi corrected
driven daily at 12psi 260 hp tune ,-most of which is unchanged table data from the late Escos EEC-IV
Awesome sleeper!
I am in Canada and building an Escort RST clone.
The car is 1986 escort, engine is 1.9 HO.
The head is a 1987 HO being ported - using Burtons stainless
intake and exhaust valves. The intake is a ported HO manifold,
also using a BBK 57mm throttlebody.
Connecting rods are Cosworth.
I havent ordered pistons yet - not sure where to buy from
probably JE, Venolia or Arias.
I will be using the 1988 GT roller lifter camshaft.
Using Crower dual springs and retainers.
What pistons are you using? CR?
Did you have your cylinder head flow tested after the modifications?
What head did you start out with - 1.9 SEFI?
before balancing.
Rods ,valves and main caps were hardened -treated with the crank as a freebie.. if or when they let go I'm thinking about trying a YB /RWD setup ..
I will probably have enough spares from my Escoss project to build up a second light duty engine.
Besides, the car is so cut up /welded , knocking out another chunk for a hump wouldn't be too crazy
The head is originally a 1.9l
The kent-37 is a little overkill on the street
I welded a tab onto the cam for the cam sensor trigger. That and pressing in the new bearings took too much effort to bother with again....
The D shaped combustion chamber was milled to a full dome (50cc, plus .030 over on the head gasket gives me about 8.4:1 CR
Larger "pinned in" valve seats to suit the larger valves
The valves are from a 2.0l US CVH 97+ , they were cut about an inch shorter and re-grooved for improved retainers
The retainers and locks are titanium units from "Crower"
The double valve springs are "Crane" units listed for a Ford 2.3l OHC turbo engine, as found in the Thunderbird ,Mustang, Capri ,Xr4ti
And just for shits and giggles I milled those ugly lines of the valve cover casting
Would have modified the 2.0l head but theres that annoying variable intake runner foolishness. It had an opposite effect on the flow at high RPM and limited the amount of porting that could be done
...Fine and good torque for an economy car ...worthless for high revs
Thanks all for your kind comments
Flow data below
Flow at 28" Lift .100 .200 .300 .400 .500
Cylinder #1 Intake .110 .345 .500 .670 .870
CFM 61.31 108.65 130.78 151.35 172.54
Exhaust .075 .225 .325 .395 .450
CFM 50.56 87.80 105.37 106.20 124.11
Exhaust % flow of Intake 82.5% 80.8% 80.6% 70.2% 71.9%
Improvement v. stock 22.1% 24.0% 21.9% 21.5% 22.0%
Cylinder #2 Intake .115 .340 .475 .675 .890
CFM 62.48 107.89 127.40 151.85 174.40
Exhaust .060 .205 .305 .385 .445
CFM 45.28 83.90 102.15 114.65 123.30
Exhaust % flow of Intake 72.5% 77.8% 80.2% 75.5% 70.7%
Improvement v. stock 22.2% 23.9% 19.8% 21.6% 21.8%
Cylinder #3 Intake .120 .365 .495 .660 .865
CFM 64.04 111.65 130.05 150.21 171.95
Exhaust .060 .220 .330 .410 .465
CFM 40.40 80.54 100.30 113.20 126.00
Exhaust % flow of Intake 63.1% 72.1% 77.1% 75.4% 73.3%
Improvement v. stock 21.9% 24.0% 20.1% 21.4% 22.0%
Cylinder #4 Intake .105 .345 .485 .635 .845
CFM 59.75 108.52 128.75 147.25 170.00
Exhaust .060 .220 .335 .420 .480
CFM 40.40 80.54 106.95 119.90 128.18
Exhaust % flow of Intake 67.6% 74.2% 83.1% 81.4% 75.4%
Improvement v. stock 21.8% 24.1% 20.3% 21.3% 21.9%
It will almost fit too ,except the cross pipe wont clear and the outside bolt holes are not drilled ...
ford used only the center bolts to hold it down (and if I'm not mistaken, wont have corresponding holes in your 1.6l head)
Thank you for the head flow data!
I dont have pics of the car posted yet.
You mentioned the heads being from a 1.9.
Were they from a 1.9 SEFI? or an early 1.9 carburettor engine (with the heart shaped chamber)
The SEFI 1.9 I have seen have very small intake ports with a restriction to make them swirl the air - swirl ports.
Do you have any pics of the heads when you ported them?
I would love to see the intake ports.
1.9l SEFI the dome was D shaped and the valves were tiny
Intake manifold
![](http://img.villagephotos.com/p/2007-1/1236955/portmatchsm.JPG)
just started in the first pic , half finished in this pic
I dont have a single pic of the head side ,it's due to come off
for winter soon ,I ll try to snap some then
Intake manifold
Thanks, the whole bit was done on a $3000 US budget. Unfortunately at that price, pretty was not an option.
Remember this is my daily driver and it's not even a "REAL" escort.
Hardly worth making a show car out of, but it does make a good auto X or Ford day track car and lays down a decent quarter mile on the drag strip.
Matt Baxter
16-09-2015 08:30 PM
