my cossie
my cossie
hi all im new here.
here some pics of my cossie 2wd have it for 2 months now
[img][/img]
[img][/img]
its got full leather
shiny bits a lot
t38
kentcams
rs500 cooler
cheers from holland
[img][/img]
[img][/img]
shiny bits a lot
t38
kentcams
rs500 cooler
cheers from holland
Originally Posted by Alan s1
Looks very clean whot power is it running with that T38 and whots the rest of the engine spec
mahle 4x4 pistons
crankshaft balands
arp studs
forge motor sport actuator
garrett t38 hybride turbo met 360 gr lagers
3 layer cometic head gaskets
some headwork
kent bd 10 cams
kent pulleys
msd bobine
msd ingition system
pipercross airfilter
3 bar map sensor
788cc motorsport injectors
omp 6 pads clutch
3 inch exhaust
forge motorsport oil seperator
rs500 cooler
samco&roose boost and water
and maby more
cheers
Originally Posted by JeroentjeRS
sounds like a proper motor mate . Who worked on the car?
its got a full retso in 2003
but the engine isent running good at the moment so have two sort it out first.
but its just as guick as an m6
mahle 4x4 pistons
crankshaft balands
arp studs
some headwork
kent bd 10 cams
kent pulleys
msd bobine
msd ingition system
3 bar map sensor
omp 6 pads clutch
3 inch exhaust
rs500 cooler
and maby more
cheers
Would love to get a T38 for mine as its running "BLACKS" but due to cost its staying with its T34 atm But for now its not on the road so time will see
@ Dancosy,
Dit is een supernette Sierra, en je vergeet nog aardig wat mods
Deze auto is van mijn vriend Eric geweest en was toen in SUPERstaat.
Wat heb je er voor problemen mee, of zijn ze al opgelost?
Groeten,
Bas
Groeten,
Bas
Originally Posted by Cosworth Bassie
@ Dancosy,
Groeten,
Bas
Groeten,
Bas
he bas ik weet het heb eric toen ook aan de telefoon gehad toen ik hem ging kopen
hij is nog steeds heel netjes.
alleen me koelwater zakt en me olie peil stijgt en dat is vreemd voor een cosworth! normaal zakt je olie peil.
hij staat nu al een poosje stil in de garage. ga binnenkort het een en ander demonteren om hopelijk iets te kunnen vinden..
hoe gaat het met jou ombouw?
gr dancosy
Met mijn ombouw gaat het goed. Beetje stagnatie maar de GT30R komt erop
Groeten,
Bas
Russ Payne
25-09-2015 08:29 PM
