Engine is back in.............
.From this:-
![](https://img.photobucket.com/albums/v25/amigafan2003/DSC00014.jpg)
To this:-
![](https://img.photobucket.com/albums/v25/amigafan2003/DSC00013.jpg)
To finally this:-
![](https://img.photobucket.com/albums/v25/amigafan2003/DSCF0023.jpg)
![](https://img.photobucket.com/albums/v25/amigafan2003/DSCF0021.jpg)
Nothing major - replaced every oil/water gasket on the bottom end (front crank shaft, rear crank shaft, aux pulley, sump gasket, distributor o ring seal, water pump gasket) - guys that built the engine hadn't used quality gaskets (instant gasket in some cases - eurgh!) so I thought I'd do it properly myself using Cometic AFM gaskets where I could (if it's good enough for a Focus WRC, it's good enough for me!).
Well chuffed with the results - donw around 200 miles in it so far and it hasn't dropped a single drop of oil or coolant.
Whilst the engine was out, I finished up some interior bits as well:-
![](https://img.photobucket.com/albums/v25/amigafan2003/DSCF0024.jpg)
![](https://img.photobucket.com/albums/v25/amigafan2003/DSCF0026.jpg)
Namely fitting the air/fuel ratio meter in the dash and the corrsponding Lambda sensor in the exhaust manifold. I think the AFR compliments the ignition barrel relocation and the push button starter nicely. Gauges at the top (left to right) are water temp, oil pressure and voltmeter. A boost gauge (an expensive vacumn gauge atm
is sat in a Nomad A pillar pod. Remaining space is being saved for a nitrous pressure gauge ![Wink](https://passionford.com/forum/images/smilies/icon_wink.gif)
Now all I've got to do is get the courage up to spray the dash matt black!
To this:-
To finally this:-
nice job bro, is that a 2 litre pinto ? what sapphire is it ? 2.0glsi ?
Car is based on a D reg 2.0i Ghia Sapphire - few pics of what it looks like now:-
![](https://img.photobucket.com/albums/v25/amigafan2003/SapphSideRight.jpg)
![](https://img.photobucket.com/albums/v25/amigafan2003/Robs_Sierra_03.jpg)
![](https://img.photobucket.com/albums/v25/amigafan2003/Robs_Sierra_01.jpg)
![](https://img.photobucket.com/albums/v25/amigafan2003/sapph3.jpg)
ekjim
17-08-2015 08:57 PM
track.focus'd
12-08-2015 05:53 PM
