cvh clear cam belt cover made at last!!!!!!!
ive made them.
the close up pic is not the final item as it has a cutout in it.
the ones i will sell will be the full length.
they look well smart and there may still be one left on ebay but they are selling fast so thats why i didnt put this post as an advert, there would probably be none left by the time you read this.
i am making plenty soon
Originally Posted by kik1.6se
Looks cool
How much do you sell them for? My nice shiny vernier pulley is hidden away at the moment.
Kirk
Kirk
Spanner monkey
They look the nuts mate,
will you bee supplying a tube for each bolt so you can tighten the bolt right up without bending the cover? - just an idea!
I had some made up a few years ago when i worked for Ford in the development centre, Even had the ford logo on - basically a clear cast of the original but the heat under the bonnet of the turbo's seemed to warp them!
they are light and dont need to be tight at all.
you can just nip them up by hand with some locktight on the screws and they sit fine due to the rubber seal supporting it nicely.
the standard cover is abs and is quite thin, the acrylic i use is 3mm thick and takes more for it to warp.
rog
04-09-2015 07:24 AM
