Sierra sapphire coswrths breaking 2wd and 4x4
HERE WE HAVE SIERRA SAPPHIRE COSWORTH 4X4's AND 2WD'S .
2WD COSWORTH STAGE 3 AND 4X4 STAGE 1
ALSO HERE IS A STAGE 4 SAPPHIRE 4X4 COSWORTH BUT NOT BREAKING AS OF YET
IF WHAT YOU WANT IS NOT LISTED JUST CALL ME
ALL 3DR PARTS PRICES £POA
SHELLS AND ID OFFERS
LEATHER INTERIOR £ 400
CLOTH INTERIOR £225
2WD DASH £ 40
BLACK DASH £ 50
FACELIFT DASH £60
CLOCKS £50
INSTUMENT DISPAL PANEL £10
2WD COWLING £20
4X4 COWLING £25
INDICATOR SWITCHES £10
INTERIOR PLASTICS VARIOUS
STEERING WHEEL RS 500 £75
STEERING WHEEL 4X4 £65
LEATHER GEAR GAITER £15
LIGHT AND DARK CARPET £40
HEADLINING £20
ELECTRIC SUNROOF MOTOR/PLASTIC £40
PARCEL SHELF £ 25
REAR QUARTER PANELS INSIDE £10 EACH
IGNITION BAREL HOUSING £20
ABS ECU £20
LEVEL 6 ECU £150
INSTUMENT ECU £10
BOOT CARPET £15
BOOT RUBBER £10
BOOT SIDE CARPETS £10 EACH
HEATER MATRIX £35
ALL THE RELAYS FUSE BOX £ VARIOUS
ALL THE RELAYS UNDER THE DASH £ VARIOUS
OUTSIDE
4X4 BONNET £120
FRONT BUMPER £185
FRONT BUMPER STRIP £15
BACK BUMPER £70
SIDE SKIRTS COMPLETE £120
SHARK TOOTH WHEELS £250
LATTICE WHEELS £130
BOOT LID AND SPOILER £75
SUNROOF £65
DOORS X4 £50 EACH
ELECTRIC WINDOW MOTORS £15 EACH
CENTAL LOCKING MOTORS WITH HANDLES £15 EACH
WING MIRRORS £15 EACH
HEADLIGHTS £40 EACH
BACK LIGHTS £40
BACK PANEL £15
FRONT INDICATORS £15
SIDE REPEATERS £10
GRILLE £45
WIPER PANEL £10
WHEEL NUTS £20
LOCK SET £35
ENGINE AND AUX
STAINLESS EXHAUST 2WD AND 4X4 £200
2WD ENGINE COMPLETE £2150
4X4 ENGINE COMPLETE £2500
4X4 BOTTOM END COMPLETE £1000
GREEN INJECTORS £120
3 BAR MAP SENSOR £45
THROTTLE BODY COMPLETE £60
2 BAR MAP SENSOR £20
CRANK SENSOR £20
WATER TEMP SENSOR £10
AIR CHARGE SENSOR £10
ALTERNATOR £45
ALTERNATOR 4X4 BRACKET £15
PAS PUMP £45
PAS POLLY V PULLY £15
IGNITION AMP £20
AMAL VALVE £20
ALLOY HEADER TANK £60
SWIRL POT £45
4X4 INTERCOOLER £70
2WD AND 4X4 ENGINE LOOM £85
ALLOY RADIATOR £100
STANDARD RAD £55
FANS £30
COIL £10
SAMCO TURBO HOSES £70
SAMCO RADIATOR HOSES £90
MAP SENSOR BRACKET £15
CAM BELT COVER £45
AIR BOX £35
ABS PUMP 2WD AND 4X4 £45
STAINLESS STEEL TOP MOUNTS £20
DUMP VALVES £40
4X4 CROSS MEMBER £20
2WD CROSS MEMBER £20
STRUT BRACES £35
VARIOUS HOSES ££££
CLUTCH CABLE £10
SPEEDO CABLE £10
ACCELERATOR CABLE £10
SLAM PANEL £20
WIPER MOTOR £10
HEATER BLOWER £15
HORNS £10
MOTORSPORT PLUG LEADS LIKE NEW £100
TRANSMISSIONAND RUNNING GEAR
4X4 GEARBOX £250
2WD GEARBOX £400
GEARBOX MOUNT £40
STARTER MOTORS £50
STEERING RACKS £75
FRONT ARCH COVERS £20 EACH
FRONT DRIVE SHAFTS £100 PAIR
FRONT DIFF £70
FRONT SPRINGS £15
FRONT PROP £60
FRONT HUBS 2WD/4X4 £100
FRONT BRAKE CALIPERS 4X4 £100
FRONT BRAKE CALIPERS 2WD £100
FRONT GROOVED AND CROSS DRILLED DISCS £55 PAIR
2WD/4X4 FRONT ANTI ROLL BAR £25
TRACK CONTROL ARMS £25 PAIR
TRACK CONTROL ARMS POLYBUSHED £40 PAIR
FRONT ABS SENSORS £15 EACH
REAR ARCH COVERS £20 EACH
REAR PROP SHAFT 4X4 £35
REAR PROP 2WD £50
REAR BEAM £40
REAR ARMS £40 EACH BARE
REAR DRIVE SHAFTS 2WD/4X4 £100 PAIR
REAR SPRINGS £20
REAR 4X4 DIFF £150
REAR 2WD DIFF £175
REAR 4X4 DIFF £145
REAR GROOVED AND CROSS DRILLED DISCS £55 PAIR
REAR HUBS 2WD £90
REAR HUBS 4X4 £90
REAR BRAKE CALIPERS 2WD/4X4 £100
REAR ANTI ROLL BAR £25
REAR ABS SENSORS £15 EACH
HAND BRAKE CABLE £10
PETROL TANK £30
FUEL PUMPS £20
FUEL PUMP CRADLE £25
KONI SUSPENSION 2WD/4X4 £150 SET
CALL ME FOR MORE INFO AND PHOTOS OR EMAIL ME ON 07518180477 OR EMAIL
ALL THE PARTS ARE AVAILABLE AND CARS ALWAYS COMING IN FOR BREAKING SO IF THE PARTS ARE NOT THERE JUST CONTACT ME.
PAYPAL IS MY EMAIL ADDRESS
email me at gary.bell360@gmail.com or call 07518180477
CLOTH INTERIOR £225
2WD DASH £ 40
BLACK DASH £ 50
FACELIFT DASH £60
CLOCKS £50
2WD COWLING £20
4X4 COWLING £25
HEADLINING £20
PARCEL SHELF £ 25
ABS ECU £20
LEVEL 6 ECU £150
INSTUMENT ECU £10
BOOT CARPET £15
BOOT RUBBER £10
HEATER MATRIX £35
OUTSIDE
4X4 BONNET £120
FRONT BUMPER £185
BACK BUMPER £70
LATTICE WHEELS £130
SUNROOF £65
DOORS X4 £50 EACH
HEADLIGHTS £40 EACH
BACK LIGHTS £40
BACK PANEL £15
SIDE REPEATERS £10
GRILLE £45
WIPER PANEL £10
WHEEL NUTS £20
LOCK SET £35
ENGINE AND AUX
CRANK SENSOR £20
ALTERNATOR £45
PAS PUMP £45
IGNITION AMP £20
AMAL VALVE £20
SWIRL POT £45
4X4 INTERCOOLER £70
ALLOY RADIATOR £100
STANDARD RAD £55
FANS £30
COIL £10
CAM BELT COVER £45
AIR BOX £35
DUMP VALVES £40
STRUT BRACES £35
VARIOUS HOSES ££££
CLUTCH CABLE £10
SPEEDO CABLE £10
SLAM PANEL £20
WIPER MOTOR £10
HEATER BLOWER £15
HORNS £10
4X4 GEARBOX £250
2WD GEARBOX £400
GEARBOX MOUNT £40
STARTER MOTORS £50
STEERING RACKS £75
FRONT DIFF £70
FRONT SPRINGS £15
FRONT PROP £60
REAR PROP 2WD £50
REAR BEAM £40
REAR SPRINGS £20
REAR 4X4 DIFF £150
REAR 2WD DIFF £175
REAR 4X4 DIFF £145
REAR HUBS 2WD £90
REAR HUBS 4X4 £90
PETROL TANK £30
FUEL PUMPS £20
Jack and the Beanstalk
15-08-2015 04:27 PM
09-08-2015 07:03 PM
