3 door cosworth swap for escos
As per title who would like to do a swap
spec:
Ford Sierra Cosworth 3 door in Diamond white 330 bhp stage 3 tuning HPI clear
I have a binder full of history for this car including all the stamped service book,manuals,engine rebuild,all parts upgraded and fitted plus service work etc.
It drives amazing and very powerful when the boost comes in not to laggy as runs a t34 with 48 housing.
The outside is stock apart from 500 lower front splitter and some RS badges on the wing.
The paintwork had a tidy up this year with the front bumper and parts of the kit having a spruce up the bodywork is amazing with no rust spots anywhere and only a few pins dents which i was planning to get done £100 to do the whole car.
The interior is stock too apart from 2 guage pillar pod fitted boost guages etc but will put the standard one back in. All in good nick with no sagging or rips or wear marks as you would expect for a well looked after car.
Spec:
Nice Jvc head unit cd with graphic
6x9 speakers mounted in rear parcel shelf have a spare uncut one as well, Currently has a base bin fitted with amp but will remove this before sale.
Scorpion 4" Exhaust system
Avo coil overs nearly new
Polybushed all round
Uprated Tarox discs and pads all fairly new
500 Pace intercooler and pace alloy rad
Bailey Breather kit
Bailey header tank
Bailey alloy turbo damper
Monster fabrications alloy heat sheild
Front and rear omp alloy strut brace
Group A KandN filter
Full Samco hose kit water and boost
Atm dump valve
T34 Stage one turbo and uprated actuater
Greens 3 bar map and pts stage 3 chip runs 22psi currently
Engine just rebuilt with 0.5 over sized pistons new mains and big ends all new valves,guides and stem seals all changed head in perfect condition have pictures of all the build and receipts for all the bits.
Has also had a refurbed gearbox and diff fitted before i got it supplied by the last owners and has receipts for fitting.
Bad points:
Head lining to do with a clean in a couple of places a couple of marks on the seats(very minor being picky but like to give all the facts) and dash has a few cracks usual with the 3 doors. Rear bumper has has a couple of light marks touched in and i mean minor.
Any questions please feel free to ask. Will come with original plate unless you want to buy the private plate too and will come with hocks not the rl7s.(plate £500 valued @£1350)
Only up for sale to buy or swap for a escort coswrth
Ian
spec:
Spec:
Bailey Breather kit
Bailey header tank
Atm dump valve
Bad points:
Ian
COSWORLD
14-08-2015 07:40 AM
