mk 6 escort ideling trouble
whats controls the idel on a mk6 97 1800 ghiax? the car struggles to idel sometimes and dies
if you cometo a junction and pout in neutral it drops right down and gets a bit wobbly or cuts out, anyone help?
thanks james
thanks james
Legend
Try things in this order [cheapest parts to most expensive]:
1. Check and clean Air Filter and any breathers [unlikely to cause the problems you said, but not unheard of]
2. Check Idle Control Valve and replace if necessary
3. Check Potentiometer and replace if necessary
And let us know how you get on
Take the idle valve of give it a good clean spray wd40 inside to lubricate the spring put it back on reset the ecu and you will be away. Had the same trouble with my GTi done it twice now in 2 years on my car.
the idle speed control valve is underneath the throttle body bolted to the manifold, bit of a pig to get to. best off going from underneath with an 8mm (i think) spanner.
it works the same as ya corsa ie spring, you can clean it but it wont last too long, best off getting a new one.
if that dopesnt solve the problem, check the PCV valve on the front. underneath the manifold, if that is leaking it will cause rough idling too
Dr. Ickxs
15-09-2015 10:15 PM
