Music & Car Audio Chat Most of your cars have a great sound system and you love music yeah? Discuss these things here...
New build, Mk2 Golf, 4 15's walled, no bak seats etc
Old 07-09-2009 | 03:58 PM
bassboy's Avatar
bassboy
Default New build, Mk2 Golf, 4 15's walled, no bak seats etc
Hey everyone, thought I would show you a install im currently doing for a mate of mine...spec list is
Golf GTi 8v
Pioneer 5900DVD
Autoleads RCA's
US Amps AX TU600C tube amp
2 x CDT CL62 components
2 x JBL 14001 amps (1500wrms @ 2ohms)
4 x Ascendant Audio Chaos 15's
Custom box (approx 18cuft box tuned to 30hz)
Knu Konceptz cabling
2 Powermaster D3100 (3100CCA and 117Ah per battery!) AUX batteries
1 Powermaster D2400 (2000CCA and 87Ah IIRC) - front battery
4mm thick sound deadening
Second Skin Damplifier pro
The car when it arrived
Quick alteration to the front end
Unfortunately someone reversed into him within 2 days of owning the car So had to sort that out
The bonnet was bent like a banana so a second hand one was sourced and fitted along with dark crystal front lights etc...ill get some pics of the front end soon
Interior
Stripped
Deadened and expandy foamed
False Floor
Will update as we progress
bassboy
Old 07-09-2009 | 10:41 PM
bassboy's Avatar
bassboy
MDF roof now up
Hopefully more work tomorrow!
bassboy
Old 09-09-2009 | 10:45 PM
bassboy's Avatar
bassboy
Doors sound deadened...2 layers of Loudboys 4mm thick stuff!!
Started work on the guage holder today to...
Heater vent dismantled
Panel cut up and glued in place
ill get some more pics once i upload them
bassboy
Old 09-09-2009 | 11:18 PM
bassboy's Avatar
bassboy
bassboy
Old 11-09-2009 | 09:41 PM
bassboy's Avatar
bassboy
more updates
after a long day today, all the cables have been ran...false floor has been bolted down so im glad to say, i hope, we should be at the stage to begin making the wall! But thats for next week LOL!
Todays progress...
Voltmeter test fitted...ill get some better pics up soon
The back section of the MDF roof has been expandy foamed...roof is SOLID!
Front section of the roof has been smoothed out
DIRTY floor!
Cleaned up ready to go
All cables bar the RCA's are covered in braided sleeving and will have heatshrinked ends etc
I know this is extra and gains nothing for us, but the cables are secured every 6" or less
General wiring shots;
If your wondering why we have RCA's running along the B-pillar, its due to the Epicenter going to be roof mounted...which is what this is for...
Thats all for now folks! Be sure to tune in in a few days to catch the next update LOL!
bassboy
Old 11-09-2009 | 09:46 PM
jammerrs's Avatar
jammerrs
thats mint, could you please explain why that much sound deadening is better?
just to stop other sounds being heard so its only the speakers?
Old 11-09-2009 | 09:50 PM
pingu.woods's Avatar
pingu.woods
nice work there mate
Old 11-09-2009 | 09:57 PM
bassboy's Avatar
bassboy
to stop the panels from resonating at such a high frequency...when you tap a panel, the frequency of the sound it makes is relatively high pitched...by adding 1) mass and possibly 2) strength, into the panel, you can reduce flex and reduce the 'rattle' caused by flexing panels...the tap on a sound deadened panel sounds more like a thud...even if that panel moves and flexes, the sound it makes wont be very audiable...this stops the common rattling sounds you get from cars with subs in them driving down...the rattle is often so loud it overtakes the bass!!
Deadening also helps with the quality of the sound...a speaker on a solid mounting plane/baffle, will sound considerably better than one of a flimsy piece of metal...the energy that speakers use to move is really quite something
So deadening is used for 2 reasons, strength, and for dropping the resonant frequency of panels...the stronger the car chassis, the better the bass will sound...flex is kool...but it ruins low end bass
bassboy
Old 11-09-2009 | 10:45 PM
jammerrs's Avatar
jammerrs
ow right, thanks for that
Old 16-09-2009 | 10:18 PM
bassboy's Avatar
bassboy
Quick update with this, not had the chance to work on this due to the car being needed, but managed to get some work done to it today...
First of all, subs are here
AA Chaos' 15" D2's, 800wrms, 21mm xmax each way, 27hz fs
Got the Epicenter mount ready to trim
And started glueing panels together for the start of the wall build
bassboy
Old 18-09-2009 | 03:40 PM
RANJ's Avatar
RANJ
looking good
Old 18-09-2009 | 09:52 PM
bassboy's Avatar
bassboy
got a bit more work done yesterday...
Bit of a tight squeeze with the depth lol...but the fit is fine....the front face is VERY tight as we didnt want to have a step in the box.
Volume wise its over 18cuft before displacements (approx 17cuft after) tuned low
Front panel will be 3 layers of 18mm MDF same with the rear...top and sides are 36mm thick...port needs to be braced yet and the box resined and matted...hopefully the FG will go on tomorrow so it can cure until monday, then back panel on, bit of work here and there, extra baffles bolted on, and the box is built
bassboy
Old 19-09-2009 | 08:59 PM
mark's Avatar
mark
like it
wish i had the money to do this in my car
Old 21-09-2009 | 09:04 PM
bassboy's Avatar
bassboy
flaring ports;
Rounded inner corners
Unfortunately progress was halted today by running out of resin, new batch will be here tomorrow so we can carry on with the FG, put the back section of the wall in, and carry on with the boot area of the build
Few better pics of the voltmeter
Tomorrow the plan will be to finish the FG, put the back section of the wall on, make the battery box, put the final layer of MDF on the front section (totalling 54mm front and 36 everywhere else), position everything in the boot, begin the cable runs and hopefully if theres enough time, work on sealing the wall in!
bassboy
Old 24-09-2009 | 10:14 AM
Bobby Singh's Avatar
Bobby Singh
Good work
Old 25-09-2009 | 11:31 PM
bassboy's Avatar
bassboy
some more updates today...
Box completed structually (unforunately my local suppliers didnt have any steel rods in so for now we will leave it without them, and add them later should need be)
Front baffle now 3 layers of 18mm thick
Epicenter mount put up
Dash tweeter builds done
more to come
bassboy
bassboy's Avatar
bassboy
Mirror base tweeter builds ready to paint and then at a later date flock
Voltmeter up and running (LOVING the resting voltage!!)
Battery tray test fitted
Battery specs
Back wall carpeted and amps mounted
more to come
bassboy
Old 25-09-2009 | 11:32 PM
bassboy's Avatar
bassboy
Front of the wall is vyniled and the trim panels for it to seal the wall will be carpeted back for a bit of contrast
Car dont sit too bad considering the weight!
bassboy
Old 26-09-2009 | 08:37 PM
bassboy's Avatar
bassboy
subs are in
bassboy
Old 25-10-2009 | 06:46 PM
bassboy's Avatar
bassboy
Forgot to update this for a while...ops! Right, the car is now playing but the wall still needs sealing off properly...We have temp side panels up but the roof still needs sealing off as the air is still going backwards...
Definately impressed with the setup...punches hard, drops low...does well for 3k of power for sure! Subs definately need more power as there is plenty more xmax to come...the alt is BIG let down to...being only 55amp we are dropping down to around 11.9v, then the protection circuits on the JBL's kick in and cuts the volume
Some wiring pics for epicenter etc
door builds
Tweeter builds
bassboy
Old 25-10-2009 | 06:55 PM
bassboy's Avatar
bassboy
quick vid
http://www.youtube.com/watch?v=LWMuVzgHYXw
bassboy
Old 25-10-2009 | 07:11 PM
steves24V's's Avatar
steves24V's
Originally Posted by bassboy
Thats mental, how long before it pop's the screen out??
Old 25-10-2009 | 09:00 PM
bassboy's Avatar
bassboy
no idea...its got 2 stone chips on the screen as it is lol...i think once its all sealed up then he might run into some problems...especially if we up the power and subs like i want lol
bassboy
Old 26-10-2009 | 11:18 PM
Smartdj.'s Avatar
Smartdj.
Fookin hell that vid is crazy
Old 27-10-2009 | 09:08 PM
jock05's Avatar
jock05
What did you use to finish the tweeter builds?
Old 27-10-2009 | 09:18 PM
jammerrs's Avatar
jammerrs
+1 thats stupid, i absolutley love it
S3an
27-09-2015 12:39 AM
Eigdoog
48
19-09-2015 12:03 PM
cambo205
Ford Fiesta
06-09-2015 08:45 PM
hopper350
04-09-2015 01:53 AM
Quick Reply: New build, Mk2 Golf, 4 15's walled, no bak seats etc
