Dump valve or BOV??
Old May 16, 2010 | 09:27 PM
st-all-the-way's Avatar
st-all-the-way
Default Dump valve or BOV??
which is the best??
and what is the benefit of both ...
cheers
Old May 16, 2010 | 09:29 PM
lead_foot's Avatar
lead_foot
is awesome
Both the same thing.
No need for either.
Be a man, run with it.
Old May 16, 2010 | 09:40 PM
adam151082's Avatar
adam151082
The most anoying thing you can put on your car, mine laste 20mins before i ripped it back off.
Old May 17, 2010 | 08:58 AM
foxy06's Avatar
foxy06
same thing, yanks and japs call it BOV
Old May 17, 2010 | 09:07 AM
COCHYN's Avatar
COCHYN
Chav valve...noooooo!!!!
Old May 17, 2010 | 09:42 AM
Billy_RS's Avatar
Billy_RS
Neither. Both gay as each other.
Old May 17, 2010 | 09:50 AM
R5FORD's Avatar
R5FORD
well just because a bunch of insure guys on PF say its gay do it anyway
Old May 17, 2010 | 09:58 AM
Ad4m RST's Avatar
Ad4m RST
Jiu Boxu
Different things...
I'd go with a BOV at a push... DV's are strraaade urrrrp homo
Old May 17, 2010 | 11:29 AM
Jim Galbally's Avatar
Jim Galbally
no theyre NOT different things
prove me wrong
Old May 17, 2010 | 11:49 AM
Ad4m RST's Avatar
Ad4m RST
Jiu Boxu
Is a BOV just a glorified diaphragm DV then? always thought of them as separate things...
Old May 17, 2010 | 12:06 PM
EIL132's Avatar
EIL132
The BOV was invented so people with dump valves would upgrade to the same thing with a different name.
Old May 17, 2010 | 12:20 PM
Ad4m RST's Avatar
Ad4m RST
Jiu Boxu
Naaah it's cos they whooshh not tshhh innit cuzzz...!!
Old May 17, 2010 | 02:09 PM
Jim Galbally
it is a device which takes excess pressure on overrun and removes it from the intake system.
HOW it does it differs on a number of designs
Old May 17, 2010 | 02:27 PM
focusrrx87's Avatar
focusrrx87
whats the benifit of fitting them? i mean does it prolong the life of your engine/turbo??
Old May 17, 2010 | 04:19 PM
Ad4m RST's Avatar
Ad4m RST
Jiu Boxu
Does it come down to forces then...? or just purely what's applicable? why could a Scoob run a Baileys twin piston with 2.5L but RB Skylines I only ever see with BOV's? (generic I know)
Got me thinking on twin scroll turbo's now too, would they always need a DV? could you still stall them with big boost?
Old May 17, 2010 | 04:30 PM
m4tt274's Avatar
m4tt274
The purpose of a blow-off valve is to release built up pressure in the compressor housing into the atmosphere, significantly reducing the likelihood of backspin
the turbo stays spooled up, there is no compressor slow down due to stacking.
and the turbo lives longer due to boost not stacking up on the compressor blade.
Stacking is when the pressure in the intercooler hose's is greater than the turbo output- that's the noise you hear when you change gear with an element air filter, and it's very bad for the turbocharger.
With a high boost engine stacking is even worse!
Old May 17, 2010 | 04:37 PM
lead_foot's Avatar
lead_foot
is awesome
In theory yes.
But I know loads of car running 2 bar+ on GT35's, GT30's, GT28's, ect without dump valves, no problems. I'm yet to see any proof that it signifiacantly reduces turbo life span. IHMO of course.
Old May 17, 2010 | 04:47 PM
Ad4m RST's Avatar
Ad4m RST
Jiu Boxu
Ok, so all compressor stall, stacking, boost, turbo specific's aside to a degree... how do certain types of DV apply to certain engines or setups? those that do run them?
I've genuinely always seen it as someone choosing to go with a DV or a BOV, my rule of thumb is gone, devolution...
Old May 17, 2010 | 04:53 PM
m4tt274's Avatar
m4tt274
most cars running big gt30s etc dont last that long anyway so i dont imagine it would matter to them, im talking 100,000miles lifespan.
i think they do aid lifespan but i haven't personally got any solid proof, only that a good friend of mine has an rx7 with almost the same spec that flutters away, mine had a HKS BOV fitted in japan. at 70,000KM his twin turbos were absolutely shagged. myns only at 62,000KM but they are not even slightly worn when i rebuilt it. both cars run turbo timers aswel.
Old May 17, 2010 | 06:13 PM
mrjenrst's Avatar
mrjenrst
we run1 on the frst. Its not running massive boost but better to be safe and all that although chatter does scare people
Old May 17, 2010 | 06:24 PM
jammerrs's Avatar
jammerrs
chatter is better than both
yeah repost i know....but listen and tell me you want a dump valve after http://www.youtube.com/watch?v=bfVNIZ0RKik
Old May 17, 2010 | 06:53 PM
st-all-the-way
well tbh that does sound rubbish lol but i've heard some good noises from them,but i certainly wouldn have that one on my car too long if i heard it sounding like that....
Old May 17, 2010 | 07:19 PM
m4tt274's Avatar
m4tt274
in that video you can hear wastegate chatter or turbo flutter whatever you want to call it, the car doesn't have a BOV its just a noise created on lifting off the throttle, the noise is the air compressed by the turbo passing back through the compressor wheel of the turbo after the airflow is abruptly halted by the throttle closing, called compressor surge. However, in some cases, i.e. where the throttle doesn't open fast enough or is set up to only react to high boost, some chatter will remain.
The chatter noise is very noticeable on World Rally Cars, where anti-lag is used.
A compressor stall like this can cause excess stress and wear on the turbo's shaft or bearings under higher load applications of the turbo at like around 15psi and greater depending on the trim and flow rate of the compressor side.
Actual wastegate flutter occurs instead under partial boost conditions such as partial throttle near the boost threshold. It sounds like FftFftFft not ShuShuShu and is caused by the rapid opening and closing of the wastegate at boost levels near the spring pressure.
Old May 17, 2010 | 07:55 PM
Rs1's Avatar
Rs1
Comp. surge happens when throttle is open and is the real killer of turbo's. Closed throttle comp. stall most turbo's can hack but the gt's dont appreciate the abuse so much.
If you dont like the noise use a recirc DV/BOV.
Old May 18, 2010 | 02:27 PM
m4tt274's Avatar
m4tt274
i dont think chatter sounds that good tbh...
Old May 18, 2010 | 03:17 PM
Tazz88's Avatar
Tazz88
Summer time Fezzy RST :D
Chatter always wins...
Old May 18, 2010 | 03:37 PM
*beddows*'s Avatar
*beddows*
I like the sound of both to be honest. I had a hks BOV on my evo and had DV's in the past. Im in 2 minds wether to put one on my current s2 but i dont want to ruin the standard looks of the engine bay.
It seem's just because a few people on here say DV's are gay everyone seem's to jump on the band wagon like sheep
I love the sound of turbo chatter.Im gonna keep my dump valve on cause the samco hose looks shit with a chrome bung in the hole.
Old May 19, 2010 | 10:38 AM
rstoughy's Avatar
rstoughy
I have never ran one on my cossies over the years.
A few have had them fitted upon purchase but they have been promptly removed.
It all goes back to when i got my 1st cossie back in the very early 90's and spoke with Ahmed. He told me not to run one with his board so i never did.
Old May 19, 2010 | 10:44 AM
focusrrx87's Avatar
focusrrx87
so do you actually need 1? or is it a waste of £100 or so?
if theres no real benifit why fit one? other than the noise, can't decide if i want one or not but if theres no real benifit i wont bother.
Old May 19, 2010 | 11:11 AM
Rsmat's Avatar
Rsmat
im going to run 1 on the focus when the boost`s upd.
Old May 19, 2010 | 11:52 AM
Oranoco's Avatar
Oranoco
Don't. There is no benefit to fitting one whatsoever and due to how the Bosch KE-Jetronic system works it arses up the way the car drives and you will often have stalling and idle problems. Even those who love dump valves will usually admit the RS Turbo drives better without one.
IMHO do not fit one unless you really have to. My Escort doesn't need one and is running 25psi so doesn't have one. My chipped A4 does require a recirc valve due the way in which the fueling setup works, as such it has one.
Old May 25, 2010 | 09:25 AM
Ad4m RST's Avatar
Ad4m RST
Jiu Boxu
Bit of bumpage, anyone know?
Old Jun 1, 2010 | 11:57 AM
Joshy's Avatar
Joshy
Dreamer
the type of engine dosent affect the BOV/DV,
the only things that affect it is the amount of boost you are running and the inertia of the turbo, with a big turbo like a T4 or something bigger running on a jap sled, the turbo takes longer to slow down when you close the throttle
(hence why rally cars "chatter" for longer)
dump valves just "dump" any pressure between the turbo and the throttle body outside the inlet to stop it running back through the turbo slowing it down.
if you had a turbo that spooled instantly and stopped instantly the moment you closed the throttle, you wouldn't need a BOV/DV
Old Jun 1, 2010 | 05:13 PM
Gary F's Avatar
Gary F
Can you run a T4 without a dump valve at about 34psi?
Old Jun 1, 2010 | 06:22 PM
Oranoco's Avatar
Oranoco
Not recomended. I beleive the rule of thumb with the Garret turbo's found in RS's is anything smaller than a T4 and/or sub 30psi of boost
Nov 1, 2015 06:53 PM
DAZZER
Sep 30, 2015 08:43 PM
fordrallycar
Sep 30, 2015 07:57 PM
RS-Rikki
Sep 21, 2015 07:27 AM
rs_jim
Sep 19, 2015 08:41 PM
