what gearbox ??
Old Jan 13, 2010 | 08:55 PM
johnandhissaffy's Avatar
johnandhissaffy
white fords look best
Default what gearbox ??
hi im in the process of changing my engine in my saph to a scorpio cosworth 2.9 24v
and i really dont want the auto box what gearbox can i use for the best performance cheers
johnandhissaffy
Old Jan 13, 2010 | 09:12 PM
Gazzonator's Avatar
Gazzonator
Gary Krishna
I would think a 2wd MT75 box would fit the bill nicely.
Old Jan 13, 2010 | 09:35 PM
johnandhissaffy
what about a cosworth t5 will that be better
Old Jan 13, 2010 | 10:03 PM
Gazzonator's Avatar
Gazzonator
Gary Krishna
I guess you could use a T5 but the MT75 box is much more common and easier to find not to mention a lot cheaper.
MT75 would be my choice anyway!
The MT75 will be perfectly capaple of handling the 200 or so bhp of a 2.9 24 valver.
Old Jan 13, 2010 | 10:41 PM
johnandhissaffy
what sort of bhp can they handle i hear that they can handle 500+hp on standard internals or have i been listening to a bullshitter
Old Jan 13, 2010 | 10:42 PM
bj928's Avatar
bj928
go t5, the mt75 means having prop made as well as a gearbox made from a 4x4 box, t5 is easiest these days, bellhousings are about Ł30 plus shipping from the states, as the 2005 mustang v6 uses a t5 for the manual base model, and the v6 is the 4.0 explorer engine that is a 4.0 version of the for 2.8/9/24v cosworth engine, if your lucky you'll find a t5 and bellhousing, find an American car importer local to you and talk nicely, and if your lucky for a small fee, he'll bring it all in, in the boot of one of his imports, thats what i did, i use a guy in chelmsford.
Old Jan 13, 2010 | 10:57 PM
Gazzonator's Avatar
Gazzonator
Gary Krishna
Not at all mate. There is a 2wd version of the MT75, I know, I own a sierra with it fitted. They were fitted in 2.0 litre sierra's and granada's after 1989, scorpio's, transits etc.
As for the prop, again standard fit on 2.0 sierra's after 1989 so direct fit.
I reckon you'll get an MT75 box and prop for 150 quid tops.
Old Jan 13, 2010 | 11:00 PM
johnandhissaffy
i can see where the mt75 box will be easyer but t5 will be a better ratio surely would be better
Old Jan 13, 2010 | 11:11 PM
Gazzonator's Avatar
Gazzonator
Gary Krishna
There's all sorts of ratios mate depending on what engine was fitted to what vehicle.
Best thing I would think to do would be to have a look at the ratios in the workshop manuals and things and see what suits your needs best.
I personally think you won't go far wrong with a box out of a 2.0i sierra or Granada tbh mate.
Old Jan 13, 2010 | 11:25 PM
bj928's Avatar
bj928
the only part of the 2.0 sierra/granada box thats any good for a 24v cosworth conversion is the rear section, unless your swapping all the internals over to the hybrid box, which is pointless, the bellhousings can't be changed to fit the 24v as they don't unbolt
Old Jan 13, 2010 | 11:40 PM
Gazzonator's Avatar
Gazzonator
Gary Krishna
I always thought that all the ford bellhousing bolt patterns, apart from the duratec 4 cylinder engines were the same.
Old Jan 13, 2010 | 11:54 PM
bj928's Avatar
bj928
all the 4 cylinder engines are, but a 24v cosworth is a v6 same a 2.8 capri, part of the cologne familly of engines,
Old Jan 14, 2010 | 06:11 AM
rich123's Avatar
rich123
hi if your running staderd power then just use a v6 type 9 box cheap and will bolt straight up pick 1 up for around 40-50 quid
Old Jan 14, 2010 | 06:16 AM
rich123's Avatar
rich123
if you went with the mt75 box you would have to get a v6 4x4 box and a 2.0 2wd box and change the imput shafts in the 2wd box as the v6 is imput shaft is longer and these days ur talking the price of a t5 box when getting the 2 box's i know becouse thats what i want to do but there going for silly money at the mo i would just go for the v6 type 9 handles 200bhp easy thats what im running now on my v6
Old Jan 14, 2010 | 08:56 AM
scoooby slayer's Avatar
scoooby slayer
capri 2.8 5 speed type 9 gearbox.
Old Jan 14, 2010 | 11:31 AM
johnandhissaffy
will it be better to use the lsd from the Scorpio or is there others what sort of axle will i needs to use i will be running it on koni shocks with uprated springs and i am looking for some poly buses will this be ok for what i want ?
Old Jan 14, 2010 | 08:52 PM
rich123's Avatar
rich123
if its cheap you want yes run either a xr4x4 back axel and lsd or a scorpio its up to u
Old Jan 14, 2010 | 09:19 PM
johnandhissaffy
will it all fit without any problems
chowfornow
14
Jan 5, 2019 09:01 PM
mjonathan24
Oct 29, 2015 10:39 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
Iain Mac
Sep 30, 2015 09:39 PM
gingeRS
Sep 4, 2015 06:29 PM
