what boost will a -31 actuator produce???
Passion for Fords!
the question doesnt really make sence mate,
if you mean a T4 with a -31, with a hole of preload, and pull the feed pipe off, it should make around 40-50 psi easily.
my own T4 car ran a -31 with a hole of preload, which is the most you should ever run , and had a nice 37psi peak, holding 32 to the limiter with no issues at all mapped on air injectors,
why does the question not make sense???
you have answered my question.
you said (a T4 with a -31, with a hole of preload, and pull the feed pipe off, it should make around 40-50 psi easily).
and buy fitting a -34 with a hole of preload would that produce the same???
Passion for Fords!
if it wont make more than around 30psi with the pipe off on a -31, you have issues,
we map hundreds of T4 spec cars most on -31s and run over 30psi easily,
it would be unwise to even try to get more knowing there is a potential failure waiting to happen,
does your -34 work correctly? because the one we had on your car which you supplied didnt work it seems, as we had no boost control at all with it fitted
if you want us to give you a flat out T4 then fine, lets do it, but dont blame us when it goes bang!
yeah my -34 produces 40 psi
the actuator on my car was a old -31 when it came back down.
i removed the -34 because i was told you could'nt get the boost below 26psi.
now it won't boost more than 30psi, but does when i fit my -34.
all i wanted to know was, should a -31 produce more than 30psi with a hole of preload?
Mark RS
12-10-2015 06:01 AM
Russ Payne
25-09-2015 08:29 PM
