2.5" 0r 63mm flexi pipe needed, Where from?
a mate's got a starlet turbo, and its havein a problem of cracking the after market ss zorst.
so i'm gonna weld a piece of flexi between down pipe and exhaust. as there's nothing already fitted.
i dont wont a conpensator joint (like in Burtons) i need a weldable piece of flexi.
Cheers for any help.
demon theives stock them. They are bit shit though, they tend to fail. The join in the std RST exhasut is very good, not sure what it's called, it's spring loaded.
Cheers lads
Thats the kiddie, wot sort of money for a 63mm X 100mm flexi joint like that?
i had a spring bolt joint on my tt,
but with extreme amount of engine movement (ie big power or bad design engine/gearbox mounts) i wouldn't say there up to the job, as on my xr2tt with 180-200 bhp, vibratecnic mounts and spring joint, it still cracked twice, and after i fitted a flexi never had a problem.
Originally Posted by Steve_B
Do you mean 1 of these??? if so I maybe able to help wit ha mild steel 1 thru work
just finding my feet
tell him to look at his mounts first mate,,,,,, as my mates got a starlett turbo and hence NEVER bust his one yet and hes aint standard and i gave it a good beasting recently and it was fine
Originally Posted by bassboy
hi mate i needed one of them on my escort...got mine done from Powerflow for Ł60ish supply and fit...was a 3" one to
bassboy
bassboy
