2wd v 4x4 cossie head quicky,,,
1 Post
other than the obvious turbo hanger mount - is a 2wd head any different than a 4x4 head...? also will a t34 fit on a 4x4 manifold on a 2wd head - ie is there enough space between the turbo and the hanger casting..?
ive foudn a good cheap 2wd head and need to know if should buy it..?
Norris Motorsport
2wd heads have slight differences but nothing that will cause any issue. The big two visual differences are the turbo hanger bracket and open exhaust side water jacket on the head face. In addition the 2wd head does not have the oil feed union for the turbo, so you will need to take the oil feed from the side of the block.
Also bare in mind that if the head is an 86 HF 6090AA with two bolt stat housing then I recommend you either avoid this head or send it to me for correct modification as there is an issue with one of the water channels that requires welding.
1 Post
i know pete
the only thing was , there was a cheap complete 2wd head that had never been skimmed on ebay , for the money i thought it may be worth it - but if its not right - it not right - id rather have spent an extra 100 for the right one ...
can i come up to see you for a browse when ive got her in bits..?
ill have one of them, swap this for that, part x that and a new one of those please![Grin](https://passionford.com/forum/images/smilies/icon_smile.gif)
whar about are you exactly pete - -your website link dont work - it opens up your hosting provider.?
![Red Faced](https://passionford.com/forum/images/smilies/icon_redface.gif)
FlashRS
13
31-08-2015 06:02 PM
