how do you bleed brakes on a cossy :wall
how do you bleed brakes on a cossy i have been doing it long pedal gets hard but when i switch on the ignition the abs pump can be heard pumping and then the pedal go s soft i have 6 pot will woods on the front and std rears i just fiited with new brake lines
lloyd
right but do i still have to pump the pedal and hold down . also do i wait for the pump to stop pumping as if i bleed with it on it comes out like a tap
Stu @ M Developments
right i did this one at a time on the front and that was fine tryed the back with pumping up and down nothing realy came out switched on ignition and it was like a tap after i finished off i switched on the car pump can be heard after it finished it went all soft agine have i done some thing wroung
The Enigma
12-09-2015 10:12 PM
