Turbo removal came to a halt...
...because I need a bent spanner to get the back two bolts holding the turbo to the manifold.
Is there a something i can buy off the shelf or do I need to bend a spanner myself. Don't fancy it that's all, no access to a vice so i'm likely to do myself damage and still end up with a straight spanner
Any suggestions?
Any suggestions?
Im sure the rally teams used to be able to change them in 15 mins between stages... fook knows how!
Trip to halfords tomorrow & take alternator off see if that helps.
Cheers to all for tips
I use Short spanners and a lot of fiddly angles with my wrist! lol
its only that One nut on the back of the turbo by the head
thats the probelm really. but i managed ok
Robs & pee vee, short spanners!?!? How fookin short are we talking?
This is on a 4x4 saff, i cant see how you'd get in let alone get any leaverage?
Just been to halfords, not that hopeful but gonna go have another go.
They didn't sell bent spanners, just moon spanners that won't do the job. Bought some adjustable head job, might do it. Also got a cheapo 17mm to try to bend if that fails.
To those who've bent them before, did you have to heat them up?
1 Post
as u say though, all u need is a cheap 17mm spanner and a vice and a long length of tube to slide over it - you will end up donig yourslef a mischief trying to do it with a hammer
ps..
ps..
i changed mine ... bastard of a job to do very small spanner for the back engine side on (or the bent style) had to take the exhaust off the turbo on mine
not that it helps much but
https://passionford.com/forum/viewtopic.php?t=103564
bent spanner
use a heat gun or blow torch or even a cooker to get the spanner hot then bend it .halfords are best as they bend back ok.also helps if you grind down spanner a bit
Eagle, can't follow that link. Do you have a pic of this 'small' spanner. A mate of mine has bent a spanner for me, I'll have a go with that tonight, but if that fails might need a short one.
Cheers to all for posts... I'll get there in the end... or i'll get it towed to a garage
Football Cwazy
when i took my mates off i didn't have any such trouble??? only took bout 25 mins?
....thinking about it i removed the metal water pipe that runs along side the head under the turbo,and the exhaust downpipe ( this may help? ) obviously then you'll need to refill your engine coolant
Football Cwazy
Originally Posted by Dave Henshall
on a 2wd though , it much easier as there is more room to get behind IIRC
The saga continues... still can't get that last nut.
Had enough for tonight, must have spent about 5 hours in total on this fooker now!
Tomorrow night, the manifold is coming off ... gotta be easier
There's 2 studs missing that i can see anyway so gonna try to get those fixed at the same time.
What a nightmare this is.
I'll keep ya posted on my (lack of) progress... Thanks again to all who've helped out - great bunch of people on this forum
took me about 6 hours all in to swap standard to a t34 .. never done it before ... so i was happy .. oh and be carefull when you take the water pipes off as the copper type washers have a tendency to leak .. apparently you can heat them up and tap em flat .. or goto fords and get em for 27 p each ....
Originally Posted by 900ss
Ask Mr snapoff if you can't find one ?
Another thought just crossed my mind. What if I cut a 17mm spanner down and get someone to weld a socket onto it so i can put an extension bar in. That should work shouldn't it?
I don't know if you cracked this or not, but I just removed my T3 last night.
I took the alternator off, and the compressor housing off the core. I managed to then get at all of the bolts with a standard 17mm open-ender
Took 2 hours absolute max, and I'm a methodical worker
Just waiting for my mate to finish machining the exhaust housing quick-release stylee and then I can fit my new blower
Neil.
Neil.
I took my turbo off the other day took me an hour to remove and just over hour to refit...
DIDNT take off alternator or anything, just boost hoses, didnt even take out the oil return pipe
I used 3 17 mm spanners, a std 17mm short snap-on, a angled head double open ender snap-on and the one below for the back nuts...
As you can see its bent slightly (in 2 directions) plus for clearance I ground both ends down.... quite a bit LOL..
Its fiddly but you just have to keep switching spanners on each turn thats all..
1 Post
this is the only one i needed - as as above, only hoses to come off - i think i took the comrpessor housing off to re connect the oil return though - as with my big fat hands i cant fit them in the gap
