frst breather system help?
500bhp Cosworth in making
just converted my erst to efi engine what pipes go were from the rocker cover on timing belt end.
you have a pipe that goes from the rocker cover to the breather itself then 2 pipes coming of that were do they go as u havent got a metering head like before
cam belt end goes into breather pot thingie and the other end goes into it too and theres a thin pipe from the back of the block hope this helps
theres 2 pipes from rocker cover into it and one from the bottom of the back of the block and then it vents to the inlet pipe after the air filter before the turbo
