Looking at Saab 9-3T tomorrow for run around, advice please
1 Post
Looking for a cheap family motor
Been offered V plate saab 9-3 Turbo the 185bhp one, only problem got 102,000 on the clock but has history
Thought be a good family wagon, 4 doors, good boot.
What do i need to look for on these and whats iit worth, will probably get for sub £2000
have a look at www.saabscene.com
might be some handy hints in the forums bit
I used to own a 9000 Aero...225 bhp jobby. They are gnerally good engines and go on for ever if oil changed regularly....gearboxes are weak though and I know of quite a lot that wear out timing and balance chains at around the 120k mark, and ask if the DI (direct ignition) casette has been changed (the red or black module between the cam banks).They tend to go around that mileage and cost about £150 new.
ant
ant
The one main factor to look out for when buying a 93 is make sure the BULKHEAD has been modified as this will cost you 2 arms and 4 legs to carry out this repair they split around the servo and pedal box and you get movement between the o.s.f strut mount area to bulk head saab did carry out this repair under a national warantee scheme and saab may honour all if not part of the reapair costs even now so look into it before handing over any cash
But apart from that a cracking motor and go forever apart from what has already been mentioned DI packs etc
Regards Doug.
Regards Doug.
big_Rad
15-09-2017 09:36 AM
