Air injectors and twin turbos
Would it be feasable to use 2 sets of air injectors to completely eliminate turbo shuffle on a twin turbo installation?
My thinking is that both turbos could be mapped so that they are completely matched at all revs/boost.
Yes it could be done but not many ecus have the ability to do this correctly
as most only have control for ONE waste gate.
Which ecu's can do this I couldnt tell you for definite BUT I am pretty sure T6 can.
The trouble with using independant boost controllers goes back to Cams
original requirement of no "boost shuffle".
Effectively the control required is one turbo controlled in the normal way
and the other control loop is slaved off the boost setpoint of the first.
One major flaw of this type of control is that generally both outlets of the
turbos join up together at some point before it enters the engine rather
than just feeding the cylinders that drive the exhaust turbine of one turbo.
This has the effect of promoting "turbo boost shuffle" by the average
airflow created within the intake system.
Will be a bitch to set up properly IMO
Originally Posted by madevelopments
Cam what has Rod b said, when does the problem start and stop.
Mark
Mark
Mines has the slightest hint of shuffle now and again but coming off the throttle for a sec then reapplying it sorts it.
Re: Air injectors and twin turbos
Originally Posted by wimwerf
T6 a propper ecu cam no toytime crap like motec autronic etc
Mark
Mark
If it is when they start to open then adjust wastegate opening to trim it,
The only time I have felt it on a TT car it was part throttle below wastegate min pressure so you cant do anything.
Mark
Mark
Mark
Mark
Mark
Mark
Mark
Mark
I only get it occasionally under load at about 3800-4000rpm with about 0.8-1.0 bar in 4th/5th/6th but if I come off the throttle then nail it that sorts it. Probably could be mapped out but it happens so infrequently its no biggy.
Cam so the min boost you can run across the rpm range is .5bar
Mark
Mark
Mark
Mark
Mark
Cam as this is just above the min boost I would look at the wastegate balance more than a boost control issuse,
Autronic could control 2 air injectors on a duty cycle but IMO the problem is wastegate balance first but this would be very diff to cure completly.
Mark
Mark
Ive got some new turbos to try but I need to convince Rod to allow them to be fitted esp as they came from the States he is very sceptical
Mark
i was going too run a pectel t6 on my skyline, but was told the pick up on the cam pulley sensor couldnt be done yet as they were working on a system for it. so went to life racing f88 instead. i would be very surprised if this system couldnt run twin air injectors.
mine actually flutters slighty at the mo but its cos the wastegates are not set up right yet. i am hoping it will be cured some too. didnt know it was a common thing on tt setups
There you go, GTR engine on T6, can keep the cam pulley sensor if want, but this one hasnt...
fair play fella, was told by my tuner it couldnt be done yet. hence went life racing.
he did say it could be picked up from the crank sensor or something. never mind...lol. i have been told the life racing is a better system . dont know weather it is. but does for me. same money as a t6 tho
Life racing are all ex Pectel people never seen a life racing ecu's but i'd imagine they are similar to the T6/T10 ecu ranges....
Quality ecu's I beleive I know Tony Bardy is using them on some of the rallycross cars...
