3dr fuel pump cradle/tank Quip
What options are there for tidying the cradle up? can you still get them from ford + the rubber bits/clamps? does anyone do any aftermarket ones or is it just a case of blasting my one and powdercoating it.
Also can you still get tanks are they the same as other sierras??
On a more technical note do i have to use a banjo fitting on the outlet of a Grp A pump or will a 90 degree swivel be ok? I have heard that the banjo is needed to equalise the pressure in the lines.
any advice/input welcomed
I brought a new Fuel pump cradle last week from Ford, it took nearly 2 weeks to come, forgot to try and order the clamps for the pump and filter, i will try later in the week, And i brought a new fuel tank from Ford about 18 months ago. so parts should still be available.
Steg
Steg
The bracket for the pump should be OK - I got mine a few months ago - but forgot to get the two for the filter and they are not available as of last weekend.
The rubber insulators are sold in packs of 10 and you only need 3 (or 4 - can't recall) Whatever, I have spares!
JK12
33
26-04-2021 12:09 PM
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
