Removing rusted on brake discs???
well, last night i had a go at fitting me cossie front setup.
but couldnt get the bastard disc off....
whats the best way to go about it??
get a bigger hammer????
im gonna invest in some copper grease for when the new stuff goes on....
NOTe dont keep whacking the disc in one pace tho. Keep spinning the disc. Big hammer dont mean hit it with max strength or youll fook the hub/bearings/splines
Originally Posted by fudgeass
any other ideas ![](https://passionford.com/forum/images/smilies/tantpis.gif)
Be careful you don't miss and hit the shocker, wheels studs etc, and batter the shit out of it.
Before you put the new discs on, clean the hub up with some emery cloth and use a very thin coating of copper grease on the mounting surface.
and im making sure i hit the bottom of the disc to avoid everything else
i was gonna take to the hub with the old angle grinder with wire brush on it to clean it up...
