Mayonaise.....
1 or 2 version
i found this INFO
when i had my rs 2
When you start the car up it should idle perfectly at around 950 rpm. Check for blue smoke on start up, which is a sign of the engine burning oil. And it is normally the valve stem oil seals letting oil past. You should also check in the header tank for mayonnaise, which means the head gasket is leaking "QUOTE FROM THE LINK"
http://www.rsownersclub.co.uk/rsocbb...ead.php?t=8639
or as NUTS RuS said Condensation hopefully
i found this INFO
when i had my rs 2
I thought condensation, however, there is no smoke on startup or at all, oil pressure is at around 4 bar cold but drops to less than 1 bar when hot, any ideas what the oil pressure should be? Thanks for the input so far guys
NUTS RuS
was bang on then
ive got some in my power steering header tank
think its the same problem "but in a 15 year old car "
pondering how many times the fluid was changed may be never
fuck knows how you drain the thing though "pondering air blocks & alike
so ive left if be for now "
was bang on then
