Compressor surge
Old Jan 19, 2006 | 11:21 PM
SamERST's Avatar
SamERST
Default Compressor surge
Wastegate chatter/flutter what ever you wanna call it.
Which is the best type of air filter to get the loudest noise ?
Im after some filters for the rex and ive been offered a pair of mushroom shape foam gready jobies and dont know if there up to the job as all the cossys ive seen with loud chatter run k&n paper type filters
Will the rex be loud enough with foam ?
Old Jan 19, 2006 | 11:23 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Foam are shite IMO.
Defo K&N or Apexi.
By the way, most people refer to it as 'Turbo Chatter'. It definately ISN'T Compressor Surge, this is a VERY different (and very serious) thing!!
Old Jan 19, 2006 | 11:26 PM
Its COMPRESSOR STALL
Which is actually part of what happens during compressor surge.
Old Jan 19, 2006 | 11:28 PM
is chatter a good thing if its loud? mine is really loud these days on my S2
Old Jan 19, 2006 | 11:29 PM
SamERST's Avatar
SamERST
Not on mfi mate, we found this out on a mates s2 metering head was flucked
Old Jan 19, 2006 | 11:30 PM
Christian and Beccy
#1 in Spelling Club
Yes, Chip, it is a by-product of Compressor surge, but I still don't see that the 2 are related.
They are both caused by air backing up onto the Compressor Blades. In the case of what I refer to as Turbo Chatter, the cause of the 'back-up' is the Throttle slamming shut, whereas with Compressor Surge it is a restriction in the system causing the air entering the engine to exceed the air that can get out of the engine.
Anyway, less of the physics and back on topic!!
Old Jan 19, 2006 | 11:31 PM
oooh bollox
Christian and Beccy
#1 in Spelling Club
oooh bollox
Oh well, get one from Ford, they are only about Ł1700!!
Old Jan 19, 2006 | 11:32 PM
SamERST's Avatar
SamERST
Check all your vac hoses first though
Old Jan 19, 2006 | 11:33 PM
C+B, when you get surge, it causes compressor stall.
Then the surge goes, then the turbo starts to accelerate again, then it sruges, and then stalls.
i think we both are saying the same thing in a slightly different way?
anyway, back on topic..........
ANY turbostall is potentially bad for the turbo, it puts a lot of side loading on the shaft when it happens, which ends up at the bearings, some turbos (t3) are over engineered enough in this department for that not to really matter others (gt35r) arent.
Old Jan 19, 2006 | 11:34 PM
hmmm Ł1700 nice and cheap then.
yeh i will defo be checking everything b4 i purchase one of them.
Old Jan 19, 2006 | 11:37 PM
SamERST's Avatar
SamERST
so not a good idea on an rx7 with little baby turbos ?
Old Jan 19, 2006 | 11:43 PM
Re: RX7
At a guess, probably not, mots standard jap turbos dont like it.
Its not the size of the turbo that matters though, its the speed the internals spi, versus the weight of the blades etc, versus the size of the shaft.
Ie a T3 is fine and a larger GT35R isnt.
Old Jan 19, 2006 | 11:50 PM
MarkTurbo's Avatar
MarkTurbo
Re: RX7
I've done 23,000 miles in my car with no dump valve fitted Thats with the original turbo too, its done 129,000 miles now and is just starting to show signs of wearing out
Old Jan 20, 2006 | 12:00 AM
SamERST's Avatar
SamERST
And the question is does it chatter like a coont ?
Old Jan 20, 2006 | 12:38 AM
Stavros's Avatar
Stavros
DEYTUKURJERBS
almost every RX7 ive been in chatters a lot.
they come with recirc DVs as standard anyhow.
but still chatter with cone filters fitted.
its not a problem.
the same stuff happens, just can hear it with the filters on.
Old Jan 20, 2006 | 12:48 AM
Originally Posted by MarkTurbo
Re: RX7
Yours has a garett T series turbo, which shares a sophistication level on a par of that of fiesta turbos, not skylines, its hardly a typical jap motor
Old Jan 20, 2006 | 07:18 AM
zippyobrien's Avatar
zippyobrien
piper cross foam filters deliver a good amount of niose.
ive been told the HKS mushroom filters are pretty good to.
Old Jan 20, 2006 | 09:59 AM
Christian and Beccy
#1 in Spelling Club
Its just a shame that they don't actually filter very much. I would NEVER use one.
Old Jan 20, 2006 | 11:00 AM
SamERST's Avatar
SamERST
What about the gready mushrooms ?
Old Jan 20, 2006 | 11:22 AM
s2_rsturbo's Avatar
s2_rsturbo
imo foam is crap but had one on my t3 conversion fiesta; and chatter was still loud!!
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Chas
Oct 5, 2015 07:13 PM
BRAM
Sep 8, 2015 07:11 AM
YODI
Aug 30, 2015 01:12 PM
