mk3 fiesta bias pedal box
does anyone know if you can get a bias pedal box which fits into a mk3 fiesta? Thought i'd post before sending mine off to be modified (£££
) Thanks a lot
![Cry](https://passionford.com/forum/images/smilies/icon_cry.gif)
Danny B has just fitted a peddle box with 3 master cylinders behind my ka dash which has alot less room, plus ive got part of my roll cage that runs the width of the car behind the dash too,m so i would say that it is possible in your fiesta bro
) Thanks a lot
) Thanks a lot
even though there is no particuler way to do it
ive just had the wilwood 1 fitted to my mk2 while getting some bodywork done
) Thanks a lot
three reservoirs one for the hydraulic clutch one a piece for the brakes
![Name: P1010010.jpg
Size: 180.5 KB](https://passionford.com/forum/attachments/general-car-related-discussion/147854d1502131792-mk3-fiesta-bias-pedal-box-p1010010.jpg)
) Thanks a lot
![Banana](https://passionford.com/forum/images/smilies/banana_dance.gif)
Originally Posted by KA ZETEC
Ive got my 3 pots mounted inside the car ![Top](https://passionford.com/forum/images/smilies/smile011.gif)
) Thanks a lot
(its a mk2)
tommy had to take the bottom end apart to have my pistons skimmed to get exact compression ratio as it was a bit too high so its set me back a couple of weeks so hoping to be all dyno'd by mid feb now the money for machining/labour has put me behind
also i have still got to sort out the hydrolic clutch set up side of things,,,,
i take it brom supplied & fitted all yours,,,
i will have top see about him sending me a ready made set up to bolt on to my gearbox???
do you think thats possible?
take it your still using the bc box
hydraulic clutch master cylinder one of two
![Name: P1010008.jpg
Size: 143.6 KB](https://passionford.com/forum/attachments/general-car-related-discussion/147855d1502131792-mk3-fiesta-bias-pedal-box-p1010008.jpg)
pics a bit cluttered but i get the idea,,,
what size cylinders are you using,,,
gearbox end & pedal end???
(i know its cheey asking but saves me working it out my self)![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
![Red Faced](https://passionford.com/forum/images/smilies/icon_redface.gif)
the pedal box was mounted in the car by a local fabricator/sprayer who is painting the inside of the car & doing some welding on it,,,
its the same pedal box as yours (wilwood)
here are some pics of the right hand side mounting point,
the right hand mount has been welded to that plate & braced off of the top of the bulkhead
![Name: insidepaint030.jpg
Size: 103.8 KB](https://passionford.com/forum/attachments/general-car-related-discussion/147860d1502131792-mk3-fiesta-bias-pedal-box-insidepaint030.jpg)
![Name: bodywork007.jpg
Size: 47.4 KB](https://passionford.com/forum/attachments/general-car-related-discussion/147861d1502131792-mk3-fiesta-bias-pedal-box-bodywork007.jpg)
the bulkhead has been plated & welded both sides for strength &
here it is all painted up
![Name: insidepaint054.jpg
Size: 95.5 KB](https://passionford.com/forum/attachments/general-car-related-discussion/147862d1502131792-mk3-fiesta-bias-pedal-box-insidepaint054.jpg)
the left hand mount has been made on the steering column support as it was perfectly in line & is more than strong enough to handle half the support
il get some more pics so you can see what i mean when i go down there next as i havent had a chance yet
excellent mate
when i get mine back il post the pics of mine,,,
you got any decent pics of the clutch set up on the gearbox![Top](https://passionford.com/forum/images/smilies/smile011.gif)
Hi MK sorry I aint got back to you, been flat out with work. you want a ,750 for the clutch and a bmw 325i slave cylinder should work well on the clutch, make a bracket to fix it to so that it pushes the clutch leave that the cable would noramally pull
If you need the parts give me a call or PM and I'll order then in for you.
KAZETEC tomorrow pics with dash in to show that there no excuse about limited space inside the car. We have made optimum us of space in the KA so that the engin bay will still be clutter free and easy to work on.
cheers mate,,,
is there any particular year the 325i clutch slave cylinder comes on???
would this 1 i found be ok?
http://cgi.ebay.co.uk/BMW-CLUTCH-SLA...QQcmdZViewItem
and would you be able to make and send me a bracket to bolt on to my gearbox ?
cheers
marc
cheers
marc
here is some pics i took 2nite of the pedals in my car,,
the accelerator is set back slightly because it is disconnected from the cable otherwise they all line up perfect
![Name: pedals001.jpg
Size: 52.4 KB](https://passionford.com/forum/attachments/general-car-related-discussion/147863d1502131792-mk3-fiesta-bias-pedal-box-pedals001.jpg)
![Name: pedals002.jpg
Size: 55.8 KB](https://passionford.com/forum/attachments/general-car-related-discussion/147864d1502131792-mk3-fiesta-bias-pedal-box-pedals002.jpg)
![Name: pedals003.jpg
Size: 56.3 KB](https://passionford.com/forum/attachments/general-car-related-discussion/147865d1502131792-mk3-fiesta-bias-pedal-box-pedals003.jpg)
![](https://img.photobucket.com/albums/v104/CHICKAROO/XR%20TURBO%20REBUILD/pedals004.jpg)
![Name: pedals005.jpg
Size: 56.9 KB](https://passionford.com/forum/attachments/general-car-related-discussion/147866d1502131792-mk3-fiesta-bias-pedal-box-pedals005.jpg)
as you see before the bulkhead has had a steel plate welded on either side,,
the right hand bracket is welded direct to that & then a brace welded to the underside of the bulkhead,
the left hand bracket is the existing steering column support, which is also braced off the upper bulkhead, so nice and strong,,
theres 2 sets of holes in each bracket so i can move the pedals forward or back for prefered position
havent got the other master cylinder yet ence there only being 2 at the mo
cheers
marc
cheers
marc
