ZVH question
ZVH question
im just wondering how much it costs for a full 2.1 zvh conversion, can someone break it down for me
-parts, whats neede costs?
-how long does it take labour costs?
Just looking it to it for when my engine goes boom in the future
Custom
this is what ian howell > area 6 sent me
For the engine build breakdown, see below!
Supply donor 2.0 engine £200
Modify Block to ZE-VH inc Water pump plate £100
Bore and hone Block £77
Deck Block £32
Oil Pump £96
Water pump £27
Belt and tensioner £42
Supply, blast and modify S/H Fiesta Zetec sump £85
Modify con rods for vauxhall pistons £100
ARP rod bolts £92
Big end and main bearings £92
Crank grind £90
Dipstick and tube £22
Bottom end gasket and seal kit £32
Modify and re-face your head £55
Multi layer steel Head gasket and bolts £53
strip donor engine £25
Build 2.1 engine inc 12 month warranty £500
Strip your head, replace stem seals, re-cut seats and valve faces, clean and rebuild £95
Deck Block £32
Oil Pump £96
Water pump £27
ARP rod bolts £92
Crank grind £90
