computer people
Old Jan 14, 2006 | 11:27 AM
BM08's Avatar
BM08
Default computer people
why is it the longer your pc is on and surfing the net etc it slows down, like its not as quick as when its first turned on as it is if its left on all day or something. whats the reason behind this?
Old Jan 14, 2006 | 11:30 AM
UBster's Avatar
UBster
if there is nothing wrong with your pc and it is specced correctly this shouldnt happen. Are you running win95/98 ? earlier operating systems had bad memory management. But a fairly good modern pc with 512mb of ram and more and windows xp should be ok left on for a long time
Old Jan 14, 2006 | 11:33 AM
Thrush's Avatar
Thrush
Irritating c........
Cos the more you surf and the more content you look and and information you download (every time you view a webpage you download info, we're not just talking about media downloads), the more your computer fills up with temp files and cookies etc.
You have folders that store temp files - script, jpegs/gif, ini files etc - these are to help windows when you revisit web pages - but the more you fill up, the more bogged down you machine will become.
Old Jan 14, 2006 | 11:34 AM
BM08's Avatar
BM08
No its 2.6ghz with 512ddr ram! its not so much when your actually using it, its when you go to shut it down it seems to take abit longer to do it than it does if you have it on for like 5-10mins
Old Jan 14, 2006 | 11:35 AM
UBster's Avatar
UBster
but he said when he restarts the pc its all fine again ... what you have described would all still be on the pc after a restart
Matt
BM08's Avatar
BM08
Ahh that makes sense actually! cheers
Old Jan 14, 2006 | 01:31 PM
RANJ's Avatar
RANJ
also cpu utilisationa nd the way threading works
Old Jan 14, 2006 | 01:36 PM
DanRSturbo's Avatar
DanRSturbo
I'd do a search for spyware and a possible virus on your machine just to be on the safe side. Generally, your computer should startup and shutdown at the same speed, regardless of what you have done on it during the time it was on.
Old Jan 14, 2006 | 01:39 PM
S3an's Avatar
S3an
do a hard drive clean up, look into the properties and do the disk clean up, only take a few minutes
Old Jan 14, 2006 | 02:12 PM
Thrush's Avatar
Thrush
Matt
Some temp and temp process file will be purged on a shutdown as they might not be needed next time round the PC boots....
I would do a spyware scan as suggested aswell, and also the disk cleanup/defragment that K5SSY mentioned also
mk3ste
Oct 17, 2021 10:09 AM
Rsmat
89
Oct 12, 2015 07:50 AM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
AJC
Oct 1, 2015 06:47 PM
rsguy
44
Sep 29, 2015 03:29 PM
