Proper Cosworth Engine! 1000bhp
Sorry its not a YB though!
Interesting picture though. F1 Turbo engine. 1.5Litre V6. Cool man!
For sale for 15k if anyones interested. Martin would be able to make it fit I'm sure and Stu would probably be able to get it through emissions and able to run at Lambda 1 on the Motorway
Originally Posted by cozzybrom
pork chop
just got in to work mate
was out in the car last nite till 7am
lol
i dont get up till 3
lol
sorry i let u down
lol
lol
sorry i let u down
Some details as well if you are interested
Description
We Have available three (3) of these used ex F1 engines built around 1986, they are the GBA 1.5 litre V6 twin turbocharged engine. They originally produced 750 BHP and can run 1000 BHP with boost and fuel adjustments. They come complete with injectors and ECU's but it would need to be stripped down and checked before running. All other components like manifolds, turbos, flywheel and clutch are all present. £15k is for EACH engine, not for all of them.
History
produced in 1986, the 120 degree v angle engine ran in Formula one in a Benetton in 1987 using "rocket fuel" to attain 1000 BHP
Technical Data
Weight: 200+ lbs
Engine
Engine Builder: Cosworth Racing
Manufacturer: Cosworth Racing
Type: Formula One
Displacement: 1497 cc
Horsepower: 750 - 1000
Torque: unknown
Induction: Forced air via twin turbochargers, Fuel injected
Heads: cast aluminium alloy, 4 valves per cylinder
Block: Cast aluminium alloy
Main Caps: unknown
Crankshaft: billet type
Connecting Rods: unknown
Pistons: pressure forged
Camshaft: unknown
Valves: 4 off, poss. titanium?
Valve Train: unknown
Clutch: unknown
Pressure Plate: unknown
Flywheel: unknown
Exhaust: tubular steel
Total Time: unknown
Races: 1
not much known about these engines, they were run in a race, and removed from the car, they may have been rebuilt, but have been in storage for a number of years. They can be viewed if required by appointment only at our premises in Northampton.
Spares
crank sensors and a few seals etc.
some parts have been remanufactured
by various companies, we can reproduce
pistons etc. if required
Description
History
Technical Data
Weight: 200+ lbs
Engine
Type: Formula One
Torque: unknown
Main Caps: unknown
Camshaft: unknown
Clutch: unknown
Flywheel: unknown
Total Time: unknown
Races: 1
Spares
I remember a programme on channel 4 years ago following the development of this engine for the Hart F1 team before Ford swapped over to Benetton
They actually started first with a 4 pot ( possibly even an early YBB engine as this was around the same time)
but it could not go over 12000 revs without exploding so they went with this engine instead.
There used to be a Benetton with one of these engines fitted, in the Sports Cafe in Cardiff when it was down the bay before it closed, it may turn up again when they finish the new one in the city centre
You going to Llandow, I am hoping to dust off the old bus and take it down if all goes to plan, might see you there, still have not seen your motor either yet.
big_Rad
15-09-2017 09:36 AM
wheelwizardrefurbs
04-08-2015 06:23 PM
