lcd tv problem
Old Jan 11, 2006 | 09:23 PM
steviecossie's Avatar
steviecossie
Default lcd tv problem
i went and bought philips ambi-light lcd tv today
i seem to have a problem with it tho
when i turn it on it will only stay for 5 mins then it
turns itself off and it wont come back on unless i turn the main
plug on and off
then when it does actually stay on for more than 5 mins if i try to
change the channel with the remote control it just automatically turns itself off
i have checked all the plugs and leads and they are in the correct places
has anyone else had a similar problem
and help will be much appreciated
cheeRS
Old Jan 11, 2006 | 09:29 PM
focusv8's Avatar
focusv8
Have you checked in setup? its sounds like its going into some sort of sleep / standby
Old Jan 11, 2006 | 09:31 PM
steviecossie
I'LL try that just now
Old Jan 11, 2006 | 09:43 PM
steviecossie
checked the set up
its still doing it
Old Jan 11, 2006 | 09:55 PM
TIFF's Avatar
TIFF
Chasing Radders
Take it back
Old Jan 11, 2006 | 10:17 PM
SPADGE's Avatar
SPADGE
It sounds fooked so do as Tiff suggests!
Old Jan 11, 2006 | 10:19 PM
Westy's Avatar
Westy
bet thats abit gutting
pleased I went for the Sony over the Phillips now.. hey Spadge
Old Jan 11, 2006 | 10:25 PM
SPADGE's Avatar
SPADGE
Whatever you say Joe 90
Old Jan 11, 2006 | 10:26 PM
djbolf's Avatar
djbolf
Steer away from Phillips or Sony.
LG , Sharp , Hitatchi are good bets.
Especially the Sharps ending in GD7E
Old Jan 11, 2006 | 10:27 PM
Westy's Avatar
Westy
sticks and stones...
phillips are naff
Life of there own, Phillips turn off... they are an expensive Rip off...
Sony are the best, and so is Mr West..
Old Jan 11, 2006 | 10:28 PM
Westy's Avatar
Westy
whats up with Sony??? can understand Phillips, but Sony are quality..
Old Jan 11, 2006 | 10:36 PM
Daryl's Avatar
Daryl
I'm not to sure about phillips because i work with Sony's but try this.When the tv turns off check the standby light, Does it flash ? If it does its a fault with the set and giving the engineer a fault code to help them find the problem. If it was a brand new set (not ex display) then the factory default setting would not be set to turn off in 5 mins as every1 would be complaining about the same problem. Hope this helps.
Regards Daryl
Old Jan 11, 2006 | 11:18 PM
S3an's Avatar
S3an
been looking at the pioneer ones today and they look to have a awesome picture on them. other than that i quite fancy a panasonic one with the SD card slot so you can watch vids and look at pics you do on your digi camera
Old Jan 12, 2006 | 06:48 AM
Joris_FRST's Avatar
Joris_FRST
LG uses philips LCD panels, lol.
There not that many LCD panel manufacturers.
Your set is probably faulty.
Old Jan 12, 2006 | 03:05 PM
S3an's Avatar
S3an
well just been and purchased my new tv.
http://shop.panasonic.co.uk/invt/th42pv500cab
done a tiling job for they guy who runs the shop and got a massive discount 25%. also gave me a extended warranty of 3 years after the first 12months run out. cant wait to see it up and running( they are also installing it aswell)
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
