couple of questions ..... 200 block
what work is involved to fit a 4wd 200 block to a 2wd cossie running a 205 block??
if i have both blocks there is it just a case of changing the 4x4 sump for the 2wd sump and so on to make it 2wd again or is there more work involved ??
also what advantages does the 4wd head have over the 2wd head as i wlways see the 2wd lads running 4x4 heads
thanks in advance
thanks in advance
andrewmctiernan
08-09-2015 03:05 PM
