MAF Sensor Question - Please help
Old Jan 9, 2006 | 12:29 PM
M7 COS's Avatar
M7 COS
Default MAF Sensor Question - Please help
I've been having trouble with my RS1800 for a while and it's been suggested that it could be the MAF sensor. Yesterday I decided to swap the RS1800 MAF sensor for a 1.6 Si MAF sensor (they're not the same), it didn't really make a difference so I put the RS1800 one back on, the car is now worse than ever. Was this a really bad idea?
When I put the RS1800 sensor back on, the car kept revving itself up, going between 500 and 2000 revs, when I drove the car it kep mis-firing, lurching and eventually cut out. The only way it will run now is when the accelerator is being depressed. It's also a lot louder than before and sounds awful.
What could have happened?
Any ideas or advice appreciated.
Thanks
Old Jan 9, 2006 | 12:40 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
try just unplugging it
are you sure its not the ISCV causing dodgy idle cutting out?
they are generally shit on zetecs
Old Jan 9, 2006 | 08:40 PM
M7 COS's Avatar
M7 COS
Thanks mate.
I disconnected it but it hasn't helped much.
It seems to be worse than ever now, I think I've really knackered it this time.
Why would have changing the MAF sensor over caused so many problems?
Wish I'd never done it now!
Old Jan 9, 2006 | 10:07 PM
M7 COS's Avatar
M7 COS
Anyone?
Old Jan 10, 2006 | 08:03 AM
M7 COS's Avatar
M7 COS
Originally Posted by M7 COS
Anyone?
No?
Old Jan 10, 2006 | 08:47 AM
Stu @ M Developments's Avatar
PassionFords Creator
Ok,
The management is adaptive and it has attempted to learn how to adapt the fuel pulse to tune into lambda based on teh WRONG info you kindly supplied it with. Unplug the ecu for 1 hr and start again.
I suggest you get her to a pro with a live data scanner to ascertain what exactly is wrong with her ASAP.
Old Jan 10, 2006 | 12:47 PM
M7 COS's Avatar
M7 COS
Thanks Stu.
I think I'm going to take it to Engine Advantages.
Just hope I haven't caused any lasting damage!
CheeRS
Old Jan 13, 2006 | 12:31 PM
M7 COS's Avatar
M7 COS
Car's now booked it at Engine Advantages.
It's keeps cutting out when the MAF sensor is connected, would it be okay to drive it to EA with the MAF sensor disconnected? EA is about 15 miles from mine.
Thanks.
Old Jan 13, 2006 | 03:01 PM
M7 COS's Avatar
M7 COS
Up for Stu.
Old Jan 14, 2006 | 05:57 PM
M7 COS's Avatar
M7 COS
Hello?
chowfornow
14
Jan 5, 2019 09:01 PM
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
Neil Clark
21
Oct 1, 2015 07:02 PM
