HELP FROM SPAIN. Turbo loss preasure....
After a time going fast with the car, I see the Turbo lossing preassure, getting to 0,2 - 0,1 bar.... But, after about 10-15 seconds, the car is again pusshing the full boost...
It´s an ERST S2 90´s spec, and this totally stock, not where it can be the problem, and the people from here of Spain, are not able to find it... Can anyone help me? Somebody him step somewhat seemed?
Thanks, and happy new year!!!
Originally Posted by AndyRST
Dave have you replaced the Actuator on the turbo? They go soft when there old and they cause the turbo to stop producing the boost it once did.
Originally Posted by andrek12345
you dont speak good english for someone called Dave!!!
but as above, sounds like the actuator
I have one question... an actuator from a 4wd saff... can run on my T3?
Originally Posted by Boost Junky
I `think` the arm on the saff one is too long I`m afraid.. A new actuator should cost you about Ł60
About Ł100 a new one....
But the ERST needs it
Dave, if you need any parts bringing over, im flying into Malaga on Wednesday if its any help? I dont mind bringing across any bits as long as they're not too heavy.
Malaga it´s 750 miles ago from here
I live in the north of spain, but, don´t worry
I´m going to buy it from burton... with Ł106.73 is on my home
(8-12psi Forge actuator... For RST/2wd saff)
If it was me, i would try and get a Genuine Garret -31 actuator.
Just my perfered one
sounds to me like the amal valve is cutting the boost for some reason and then letting it back on full boost.......sommat like a faulty knock sensor possibly???
Originally Posted by * Rudey *
dave im sure i promised you some boost hoses when the car was broken i had at the time they were red samco,s you remember?
(don´t worry dude )
or boost pipes colapseing and why forget it dave? dont you apreciate kindness if i remeber rightly i was gonna give you them for nothing when they cost over Ł100 some people
Well... i pay you the costs of the delivery, and really thanks
And, dudes, i´ve found that actuator... i believe is very cheap:
http://cgi.ebay.es/Wastegate-31-Actu...QQcmdZViewItem
What you think about it??
And another question... what make the amal valvle?....
Thanks for all people... and we will know us in the next Nat Day, if i can go to UK
Well... i believe i have found the amal valvle... a picture:
Have 3 wires, two in that connection:
And the other one here:
Well, and my question is:
If i disconnect the twon-connection wire, the amal valvle will be disconected?... And, the car can go all right with that fuc**** valvle disconected?...
Thanks to all, really really thanks
