Any Evo 6 Tommi Makinen know-it-all's on here?
As per question
a mate of mine has just bought a silver one from a mitsi' main dealer. its done 35k and has a full service history, full tax/mot, the whole lot.
Its having new disks and pads up front b4 he gets it as the ones on it are warped (suprise suprise
any tips on what to look out for and things to check regular etc?
Cheers in advance
Cheers in advance
![Clap](https://passionford.com/forum/images/smilies/9c-clap.gif)
but so true
![Surprised](https://passionford.com/forum/images/smilies/shocked.gif)
Thats a bit hypocritical, especially on a Cossie website
Chasing Radders
but so true
whilst at Bedford trackday, my mate in his EVO 8 fq400, had to fill up 4 times...
Originally Posted by Rob84
As per question
Cheers in advance![Clap](https://passionford.com/forum/images/smilies/9c-clap.gif)
Cheers in advance
but so true
![Pthbbbb](https://passionford.com/forum/images/smilies/smile045.gif)
Mine ran faultlessly for the year I had it.
Check that the battery terminals are on tight from time to time they come lose and the car cuts out leaving no fault code.
Standard brakes are dire. There are options on the www.lancerregister.com site. Two piece discs that remove the warp issue.
Keep an eye on the oil level. Mine never moved but its a good idea to see if his is the same.
They get sticky actuators because the water drips in from the bonnet vents and rusts the actuator up. this results in slow boost response at best and at worst over boost issues where the car will momentarily cut out then come back in.
Best cars ever![Grin](https://passionford.com/forum/images/smilies/icon_smile.gif)
RW
Best cars ever
RW
but so true
compaired to cossies, evos are shit hot on reliability
should know got them both
Originally Posted by Redkop
Cue AJ ![Top](https://passionford.com/forum/images/smilies/smile011.gif)
Not much to look out for really, if the car's looked after it's bulletproof!
The clutch is the only thing to watch out for & as you said the discs.
But that's wear & tear, saying that i've had mine for almost 2 years & the clutch is still sweet.
I have changed the discs though.
If you go on the link given above (lancer register) you can downlaod the tme buyers guide which is awesome.
If you have any other questions just pm me mate & i'll help you as much as i can.
Yep thats the one, but then just look at the smile on your face from driving it,
worth every penny mate
as for warped discs
mike
Gareth...
A cossie aint reliable above stg1 IMO...as its very rare anyone actually looks at the major checks when converting to stg3......all they do is bung the off the shelf chip and greens and 3bar then boost it to 25psi..job done
NOT!!!
If the rear end makes noise on cornering, rear diff needs a service.
Had a couple with transfer box problems, but otherwise all reliable.... Japanese what more can you say!!
Tony
Tony
Rear diff noise on full lock could require the diff replacing (expensive) but it could also just need fresh oil and a bleed through to be quiet again. My dealer bled and replaced the rear diff oils for free.
Jap cars came with no real rust protection - rear quarters can go early. Best to get some protection done from the oldtimer fans - a full clean, wax and seal.
Obviously look carefully for accident damage - it should drive perfectly any hint of pulling, wobbliness is not a good sign.
Tyre wear, service intervals, and petrol are the main costs, as long as the rest is fine. Great fun to drive though.
Evo specific parts are extremely expensive - but there are many good specialist breakers so getting parts on the cheap is not too hard. Tuning is also not expensive.
Thanks for everyones input!!
certainly given me some info to give my mate in return for taking it for a pasting once its on his drive
![Banana](https://passionford.com/forum/images/smilies/banana_dance.gif)
