750cc injectors or greys
with what managment ??? / turbo
this my spec and altho i only have a t34 it's a stage 3 and is capable ov 420bhp
i will be looking to change the turbo after i've run it in and put a couple ov thousand miles on the engine so will be looking to fuel over between 400-500 bhp
brand new block from rod tarry bored to standard size
fully lightened bottom end and balanced from front pulley through 2 the pressure plate -julian goddfrey
new ceramic coated pistons low comp 7.2-1 with valve cut out
wingage tray under crank
arp big end bolts fly wheel bolt + clutch bolts
block is long studded wiv wrc mutli layer gasket
julian goddfrey baff sump wiv oil gate
head is from cylinder head developments as follows
16 new valves ,guides vavles and seats polished ported to grp a spec inlet manifold matched to head new bd14's from blanks new hydraulics tappets kent vs double valve spring kit new kent verniers kent manifold stud nut kits
complete new engine bolt set supplied by tremona garage
all gaskets cometic
turbo is t34 stage 3 from A1 rally on a 4x4 manifold
prob some thing i've missed
all gaskets cometic
4x4 exhaust manifold will probably restrict it to around 450bhp, as will the inlet manifold.
Greys will only flow enough fuel for around 440bhp.
Make sure the 750cc injectors are evenly matched in flow. The ones my Dad have are all over the place and flow a random figure everytime you test them.
Your options are stick with the T34 and greys (or go for an MD130 turbo from TD and greys), or modify/change the plenum, exhaust manifold and the turbo and fit siemens injectors.
I assume you have an 044 Bosch pump already?
You WILL need a live map for this.
look on mike rainbirds web site and check out the stage 3 t34 he sells
good 4 up to 420bhp
and as i said i will be changing that after i ran it in and added a few thou on the engine
cheers daz didn't know that about the 4x4 manifold
so the options later are 4 a diff manifold/turbo but if i put greys in now i'll only ave to change them later
good 4 up to 420bhp
Croppy, the reason people say the T34 is not a 400bhp turbo is because at that power level, you're running it outside is compressor map. It's a TRUE 380bhp turbo but can be pushed to over 400bhp (again, if you get 420 on the dyno, once it's in the car with everything else strapped to it like alternatoras and power steering pumps etc, this 420 may drop down to 400).
Originally Posted by croppy
no fuel pump yet as engine is not fitted untill jan and then gotta run it in
is a 044 pump the same as the gpra type ?
yeh ok m8 i knew people would start on the t34 fact but as i already had it i'm gonna use it to run the car in and to loosen the engine up a bit
if i was to sell it now(new) i'd get the same sort ov price 4 it second hand
this is why i've aked the Q about injectors and turbos
cheers m8
cheers m8
cheers m8
cheers m8
daz so what r those seimens injectors then what r these compared with
would it be worth going gt35 wiv external waste gate
or just get a t4 and something like 750cc a these are better than greys and just short ov 8greens
not looking for stupid power altho over 400 on a road car is mad
just not sure really what i want
Siemens are the "black" injectors that Stu and Kenny @ Motorsprt Developmets fit (with good results). The 750cc injectors my Dad has are Holley/MSD/Rochester injectors.
A GT35 is probably to big. I would look at a GT30 with internal wastegate.
Rochesters look like this...
Siemens look like this...
cheers m8 so any ideas what power to expect on the siemen's and wiv a gt30
what would be the best ecu/management to run it on coz as said would have to be live mapped
does the gt need a 2wd mainifold and do the injectors fit straight on or ned a fitting kit
thanx 4 ur info be back on later gotta nip out now
Basic summary off the top of my head...
Power out put is a variable depending on manifolds used but anywhere between about 430 and 550 bhp...
To make good use of the GT30 you will need to address the restrictive 4x4 exhaust and the restrictive elbow on the inlet.
You will also need to think about fuel supply (pump, wiring and piping), and if it is up to the job.
The injectors will fit straight into the manifold and fuel rail.
L8 4x4 Sapph or P8 large turbo Escort Cossie ECU will be needed without going to aftermarket management....
is it worth going 4 after market management or can standard
ecu be ok i wanna make sure it's set up the best way possible so that theres now
chance ov a meltdown
As daz sed,
The most important thing about New age high flow inj, is get them, Flow checked and matched, as the quality of them is ment to be real bad.
I run a internal gt30, (AET Turbo's) is a true 480-500 bhp turbo on a 2ltr YB.
you will need to run 2wd ex mani, and if you want 450-500 bhp, and 4 inj's you will need small turbo escos inlet as is good for 500bhp.
A std ecu can be mapped, and will be fine for the job.
mk3ste
17-10-2021 10:09 AM
07-10-2015 12:56 PM
