Gearbox question
Been working on a very lucky friend of mines car today (seeing as its bloody xmas eve) changing gearboxs on his rs turbo and we've run into a bit of trouble. We have every bolt off part from one coont which is the hardest to reach (how convinient !) and guess what... the fuckers rounded off !
Now my question to you all is what would you do in this situation ?
Bare in mind we only have one full day to finish it (boxing day)
Mike
Mike
na its the bolt that goes between the engine and gearbox just behind the turbo. to gain better access i would have to remove the exaust manifold and turbo. i was thinging of getting a drmail and cutting of the head of the bolt because its got a new box going on it anyways
you can buy a kit for removing rounded off bolts. it works in the same way as an easy out. i seen em at my local jackdaw(draper outlet).
try beating it round with a sharp chisel first if you can get access.
chowfornow
14
Jan 5, 2019 09:01 PM
